discbine
   / discbine #6
New machine JD600 series and the vermeer mc840
JD 630- 9'9"
MC 840- 10'6"
JD630 - CV PTO optional- mows only out to the side
MC840 CV PTO Standard- mows directly behind the tractor or out to the side.
Can be changed on the fly. Cutterbar angle is hydraulically adjustable on-the-go.
JD630- urethane rollers
MC840- Steel Rollers
JD630- Cast Impellers
MC840- Spring Steel Paddles
JD630-Rear Spring float
MC840- Vermeer DynaGuardSuspension!
Allows the cutterhead to swing back, up and
over obstacles, then quickly return to its original setting.
JD630- Gear drive segments with multiple seals- gear oil 7.4 qts.
MC840- Multiple Shaft design with each cutting head unit sealed using
EP-0 grease for lube
Both machines are premium quality units.
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
Informational Lot - Financing (A55314)
Informational Lot...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55302)
UNVERFERTH 330 -...
New 27ft Ratchet Strap (A54865)
New 27ft Ratchet...
New/Unused Quick Attach Auger with Three Bits (A54865)
New/Unused Quick...
