Disk Harrow
/ Disk Harrow #1
Mattc8832
West Virginia
John Deere 3032e,Snapper Pro SW20 and s200, Stihl Handhelds, BCS 830, Yamaha Rhino 700, 2 - Gravely 5260, New Holland LS 45 , 6,10 by 14 Trailer , Woods BH 6000 Towable Backhoe, Honda 21 Self Propelled, Exmark Commercial 21and shop full of tools
I was at tractor supply looking at disk harrows. Has anyone had any experience with the $799 disk harrow made of channel steel? I was wondering if I should pay $500 more get the box tubing disk. Thanks Matt
/ Disk Harrow #3
I have a 6 ft. light weight one and beefed it up a little , added some weight to it and it works fine for my garden. If I were going to be using it a great deal I would definately buy the better , heavier one . If I planned on going over sod ground i would want the heavier one for sure .
/ Disk Harrow #4
Only buy if your primary use is tilling/smoothing ground which is cultivated every year.
Be aware that angle iron frame Disc Harrows have a limited range of adjustment.
You need a minimum of forty pounds implement weight bearing on each Disc Harrow "pan" in order to accomplish much. Fifty pounds per pan is better, which generally is a Disc Harrow with 20" diameter pans.
LINK:http://www.tractorbynet.com/forums/attachments/308251-disc-harrow-selection-18-45-a.html?highlight=
In Florida all the TSC implements are produced by Tarter in Kentucky for "Countyline". You can research the Countyline implements in depth by reading the Tarter Implements web site.
LINK: Heavy-Duty 20-Blade 7' Tillage Disc - Tarter Farm & Ranch
( I would describe Tarter's 42 pounds per pan Disc Harrow as Medium Duty, not Heavy Duty.)
/ Disk Harrow #5
This is what I consider "heavy duty" :laughing: If I remember correctly, just under 1000lbs per disc. :eek:
/ Disk Harrow #6
:number1: :rotfl:
Looks almost like you were 'photoshoped' in the pix by that monster!!
:dance1:
/ Disk Harrow #7
:number1: :rotfl:
:dance1:
Actually that is a picture taken at the Tulare World AG Expo in California. It is a picture of my brother who is 6' 2" and gives a perspective of just how big this thing is. 40" disk pans, 1/2" thick.
And people say that disks are not for major ground tillage and that they are not used any more. :rolleyes: These types of disks take a wee bit bigger than a 50-60hp tractor to even move. I assume that with as many venders of these that there are at the Expo, that this type of tillage is still done in many places. ;)
/ Disk Harrow #8
Actually that is a picture taken at the Tulare World AG Expo in California. It is a picture of my brother who is 6' 2" and gives a perspective of just how big this thing is. 40" disk pans, 1/2" thick. And people say that disks are not for major ground tillage and that they are not used any more. :rolleyes: These types of disks take a wee bit bigger than a 50-60hp tractor to even move. I assume that with as many venders of these that there are at the Expo, that this type of tillage is still done in many places. ;)
I used to make the trek to Tulare for the Ag Expo every other year. Too bad it's in February. The weather was always the same as at home. Not much of a vacation. Highly recommend it to anyone who has never been. Bring your hiking boots.
Terry
/ Disk Harrow #9
Should be lots of used discs on craigslist. If you don't like it, sell it for what you paid for it. Can't do that if it's new. Honestly, though, why do you want a disc? I would advise that you consider a rototiller. A disc is the middle step of 3 steps to prep a seed bed. A tiller does all three at once. They have them on craigslist too.
/ Disk Harrow #10
I thought i read some place a few years ago that these were used for tilling up vineyards or old orchards for replanting. They would cut up the old root systems better than a subsoiler type implement. Not sure if that is true today or not.
/ Disk Harrow #11
I would recommend the tube frame disk.
/ Disk Harrow #12
Back in the early 1950's my dad drove a dozer that pulled an enormous disc harrow with discs that he said were 60". This was in very deep sandy soil where they were trying to turn the sand under and turn up some better soil.
/ Disk Harrow #13
I have about a 4.5ft wide angle iron frame disk. I use it for foodplots for deer/turkey. I have to add a 150-200lbs on top for it to cut through the sodd/grass in my fields. if i wait more than one season it becomes a chore to penetrate the grass again. If its done 2x per year its easy and pulls right through the dirt. I have greaseable bearing in it as well. It works perfect for the $200 i paid for it.
211453 (A62131)
211453 (A62131)
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2020 FREIGHTLINER...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
(1) 12.4-24 TRACTOR TIRE (A63745)
(1) 12.4-24...
STARCRAFT BUMPER PULL TRAVEL TRAILER (A63569)
STARCRAFT BUMPER...
2011 ORTEQ TANK MANIFOLD (A63569)
2011 ORTEQ TANK...
