Disk Help
/ Disk Help #1
Momboy007
San Diego
Jinma 304
Hello All,
I just got a 5 foot disk with 2 rows of disks, and do not have a clue about how to use it. It appears adjustable, the disk rows, but how should I position them?
I do not know if this is enough info to get a good answer or not, but just let me know
Thanks all in advance,
Rick
/ Disk Help #3
If it has notches to set the angle of the blades set the rear one setting less aggressive than the front setting. use aggressive setting for weeds and grass less for open dirt.Adjust the top link so the rear does not cut as deep as front to make ground smooth. Remember to lift before turning as they can break if forced side ways.
/ Disk Help #4
Start with them almost straight ahead, i.e. one position away from straight on the rear and two positions away on the front.
You didn't ask this, but DO USE SPEED when disking.
If you go too slow the disks will just roll over the clods and not slice them, wet mud will also stick to the disks if you go too slow.
Not that you should be disking in mud, but sometimes Ya gotta do what Ya gotta do when Ya gotta do it (-:
/ Disk Help #5
If you are disking rows disk the direction of the rows first and for your last disking do so the direction you will run the rows.
The comment on speed agree with it for most part but play with the speed as suggested on the angle of the gangs. If disking hard dirt you often have to slow down so the disk will not just ride on it, same for thick grass.
/ Disk Help
Thank You everyone, I will get out there and start discing immediately
Rick
/ Disk Help #8
I Love It!
I've been guilty in the past of buying things (including a disc) without being sure how they even work. :D Learning is half the fun! Good luck!
Dave
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
2014 Freightliner 114SD T/A Dump Truck (A61573)
2014 Freightliner...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
