DIY Top Link cylinder
   / DIY Top Link cylinder #11
I made my own and wish I had purchased. A store bought top link has a check valve arrangement such that when you really load the top link the check valve prevents the hydraulic pressure from pressuring up the hose. I don't mean picking up an implement, I mean the reactive force when the plow hits the dirt and the force tries to compress the top link cylinder.
When my box blade takes a big bite the hose swells and the cylinder compresses, changing the implement settings. The pressure is probably greater than my system specifications.
You get what you pay for. A cylinder and hoses is pretty cheap. Works for many including myself, but a top link with the check valve arrangement is better. If you figure out and buy the correct check vale arrangement then the price is about the same. Lots of additional effort and risk, but same price.
If your hose swells enough that the settings change and are noticeable to where your implement performance changes, I would guess that something else is at play? :confused3: But if you feel that it is solely because of the hose, then why not just get a higher psi rated hose and control the swelling-pulsing motion?
I know that on my own equipment I notice about a 1/8" movement in the ram from these pulses that you are talking about. I do not feel that 1/8" alters the adjustment enough to even consider something else. ;)
Just my :2cents:
   / DIY Top Link cylinder #12
I agree with Mtn View Ranch, I don't have check valves and I have never had a Ram move enough to cause any noticeable adjustments.
   / DIY Top Link cylinder #13
   / DIY Top Link cylinder #15
A big advantage of sourcing your upper link cylinder from Brian @ Fit- Rite is that Brian will build a cylinder specific to your tractor. You can specify cylinder length and stroke as well as lengths of your hoses and QD to match your remotes. With Agri-Supply you take what they offer.
My 2 cents worth.
Good luck!
Rick
   / DIY Top Link cylinder #16
1974 KENTUCKY TRAILER MFG 53 DRY VAN TRAILER (A55745)
1974 KENTUCKY...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2007 Ford Expedition EL Limited 4x4 SUV (A53424)
2007 Ford...
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2013 HERCULES ALUMINUM KILL TRAILER (A55745)
2013 HERCULES...
