DK4510 200 Hour Service Questions
   / DK4510 200 Hour Service Questions #11
I'd run it as is and change oil at next regular interval. Kioti recommended interval is very conservative and the equivalent of changing your car oil every 3000 miles.
   / DK4510 200 Hour Service Questions #12
Note for future reference; don't over tighten the pan drain bolts. They are steel on an aluminum pan, and can strip out fairly easily if torqued too tight.
   / DK4510 200 Hour Service Questions #13
I own a DK4510. My manual says the engine oil capacity is 2.4 gallons.
I an doing my first oil change.
When I changed my engine oil (and filter), I added that amount (2.4gal).
After running the engine for 10 seconds. Then for 5 min and checking the oil level, my dipstick indicates that I am way way overfilled.
I am now in the process of draining oil out, until i get the oil level down to the full mark.
What gives?
   / DK4510 200 Hour Service Questions #14
Let us know just how much you end up draining to reach the full mark.
   / DK4510 200 Hour Service Questions #15
I was only able to add 1.6 gallons.
I would love to know what others have run across.
I have a call into Kioti (Daedong - USA)
I'll post the results of that after I get an answer.
   / DK4510 200 Hour Service Questions #16
I just got off the phone with Kioti. (877.465.4684).
They say the manual is wrong.
While the printed manual says 2.4 gallons, the manual *should* say 1.58 US gallons.
Mystery solved.
   / DK4510 200 Hour Service Questions #17
Boy, you'd think Kioti would have issued a corrected manual or at least a sticky to put over the incorrect info in the manual. You can damage an engine with too much oil so Kioti really should be more proactive.
   / DK4510 200 Hour Service Questions #18
Quantity of old oil never seemed to match the manual's specs! ...I always pour slowly and go by the dipstick.
(2) 5' FOLD UP TRAILER RAMPS (A57192)
(2) 5' FOLD UP...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
8065 (A55852)
8065 (A55852)
UNUSED PABREAK AR650 HYD AUGER (A57193)
UNUSED PABREAK...
