Buying Advice Do I NEED or WANT a tractor?
   / Do I NEED or WANT a tractor? #1
timrf79
North AL
none
We just bought a house (November 2014) on 13 acres in North Alabama.
The property is hill side (everything is sloped, partially steep).
Out of the area about 1-2 acres is grass, the remainder is forrest.
I have a 1992 riding lawnmower, and I think I want to upgrade to a tractor with a FEL and back hoe, as well as mowing deck.
4WD to avoid wheel spin.
Eventually I want to put a trail in the forrest, possibly make a pond or pool. Maybe even have a level grass surface.
What are your thoughts?
Do I NEED a tractor or is this the kid in me wanting a "Toy"
   / Do I NEED or WANT a tractor? #2
Welcome to TBN.................
Everyone needs a tractor and everyone wants a new toy so what's the problem.
I'd say something in the 30-40HP range would suit your needs but a 25-30HP unit would work well too. Figure what you'll think you need and buy the next size up.
   / Do I NEED or WANT a tractor? #3
As you live in Alabama, aren't your REQUIRED to have a tractor?
I used to live on the Gulf of Mexico. I have at least as much fun with my current tractor, my third, as I did with either of my boats.
General use tractors are not too good on slopes, especially for operators without experience.
I would consider a Ventrac, Steiner or Power Trac brand, all of which are engineered for slopes.
There is a specialty VENTRAC/STEINER forum and a specialty POWER TRAC forum here on tractorbynet.com. You need a certain mechanical aptitude to enjoy a Power Trac.
Most Newbies think they want an optional $7,000 backhoe. A significant number of backhoes sit in storage, unattached to the tractor, after the novelty wears off.
VENTRAC LINK: Ventrac Compact Tractors & Attachments
   / Do I NEED or WANT a tractor? #4
Heavliy wooded, steep, and pond - When I see those words those task are better done by a dozer hired for your place for about a week or two depending on the size of the pond.
After the dozer work then see if you need a tractor for maintenance or if your mower will work.
   / Do I NEED or WANT a tractor? #5
Every time I say this I get in trouble after all it is a tractor web site, but consider a skid loader, it is worth a look. Unless you are actually going to plow a field IMO a skid loader will do everything you described. You will have to keep your current lawn mower.
   / Do I NEED or WANT a tractor? #6
You question is worded wrong, the question is "Why don't I have a tractor already". Its all about perspective!!!
   / Do I NEED or WANT a tractor? #7
Mistake #1, coming to a place like this asking weather or not you NEED a tractor....duh....of course you do!
   / Do I NEED or WANT a tractor? #8
I don't understand the question. You live on 13 acres, with hills, in north AL. You need tractor-like stuff done.
What was the question again?
More than likely the answer involves something that ryhmes with 'bota.
My .02. Don't kill the messenger.
   / Do I NEED or WANT a tractor? #10
You definitely need a 4wd diesel tractor with a loader.
Now do you need a backhoe? I don't know. I have one but I don't really need one but I get enough use to justify it ... at least so far. You can rent a hoe or mini excavator for about 200 a day. I don't know about putting in a pond with a small tractor mounted backhoe. I could dig a horse or cattle watering hole but a pond would be out of the question for my equipment. But there are a lot of potential uses.
As to mower deck. A tractor that takes a midmounted mower deck is going to be on the small size. 30 HP or so. But you could mow with a rear pto mower mounted on the 3pt hitch.
You didn't say how big your current mower is. If it can handle 2 acres, I say keep it and see how it goes
You can buy a new garden tractor mower for the price of my midmounted mower.
2015 John Deere 544K Articulated Wheel Loader (A55973)
2015 John Deere...
2021 DORSEY 53FT FLATBED TRAILER (A58018)
2021 DORSEY 53FT...
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2020 Ford F-250...
2004 PROCO 130BBL VACUUM (A58214)
2004 PROCO 130BBL...
1285 (A58374)
1285 (A58374)
Club Car Utility Cart (A55853)
Club Car Utility...
