Do I really need to use JD Hy-Gard fluid?
   / Do I really need to use JD Hy-Gard fluid? #11
Oil almost needs to go in a politics thread.
I used Cenex brand in my 2320 for 4 years without any issues. With an infrared reader the JD low-vis runs hotter than the regular JD oil. Heat is always an enemy.
   / Do I really need to use JD Hy-Gard fluid? #12
From the John Deere website:
Hy-Gard may be used when the following oils are specified:
AGCO Massey Ferguson: M-1135, M-1141, M1143, M-1139
AGCO White Farm: Q-1722, Q-1766, Q-1766B, Q-1802, Q-1826
Allis-Chalmers, Deutz-Allis, AGCO-Allis: Power Fluid 821XL
Case: MS-1207, MS-1209, MS-1210
Caterpillar: TO-2
Clark: MS-68
John Deere: All Weather Hydrostatic Fluid (JDMJ21A)
Deutz: Transmission-Hydraulic Fluid
Dresser: Transmission-Hydraulic Fluid (HMS B806-0002)
Eaton Hydraulics Div: Hyd. Transmission (Form 3-401-123)
Ford/New Holland: ESN-M2C41-B, M2C134-D, M2C48-B, M2C48-C, M2C86-C, FNHA-2C-200, FNHA-2C-201
IHC: B-6
Kubota: UDT Hydraulic/Transmission Fluid
Oliver: Type 55
Sundstrand: Hydrostatic Transmission
Zetor: OT-H, GL-4
ZF: Te-ML03E, 06D, 06E
So if Hy-Gard is ok to use in these applications, turn-about is fair play. But it's really only a matter of reading the label to see if the fluid meets or exceeds the JD720 spec. If your tractor takes regular Hy-Gard, that's JD720C. If it takes low viscosity Hy-Gard it's JD720D
//greg//
This info on JD's website means that JD HyGard meets or exceeds the specs for the other oils. That does not mean they meet JD's specs. My opinion is that for short term use, most of these oils would probably be acceptable in a pinch, but continued use over long term could significantly reduce the life of some of the tractor systems, particularly wet brakes and clutches.
Thanks for all of the comments guys, how much is this stuff? I only need about two gallons I think.
   / Do I really need to use JD Hy-Gard fluid? #14
It's around $16-$18/gal. Depends on local market. I paid $17/gal.
   / Do I really need to use JD Hy-Gard fluid? #15
I use a Mobil tractor/hydraulic fluid that has the JD specs listed on the label.
I get it at the local fuel jobber.
Added exactly one gallon of the JD fluid today and she's good to go, thanks again to everybody that chimed in! :thumbsup:
20704 (A55853)
20704 (A55853)
2025 GPS Trailer (A56858)
2025 GPS Trailer...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2013 VOLVO EC250DL EXCAVATOR (A60429)
2013 VOLVO EC250DL...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
