Do I really need trailer brakes?
   / Do I really need trailer brakes? #21
Yes, good too hear DK. I am a mechanic, been doing it my whole life. Too me, they appear well built. Big bearings, big spindles, and if they will haul even a small mh they will sure as **** haul my tractor around town... and then some... So I am thinking I will hang on to them, get some brakes though...
Last time I relined my MH brakes, I think they took standard Dexter brake pads.
The local Napa store had pads, magnets, spring kits, Etc. in stock that fit right on.
   / Do I really need trailer brakes? #22
Get brakes and new axles even if not required. In Texas brakes are required over 4,500 pounds GVWR. If you don't go over 30 mph you can go up to 15,000 pounds GVWR. With the new one sticker system you have to get an inspection within 90 days before a plate is issued. There is only one sticker for the plate on a trailer or the windshield for a vehicle, no inspection sticker is issued. The inspection information is in the computer when you go to get plates. Farm trailers are exempt from inspection.
Also get a good breakaway system. Cheap money to help stop a trailer the one time it gets away.
Hopkins Towing Solutions Engager Breakaway Kit with LED Test Light | Trailer Brake Controllers| Northern Tool + Equipment
   / Do I really need trailer brakes? #23
So do you test trailer brakes? How? What about the breakaway?
   / Do I really need trailer brakes? #24
I towed my TC40DA on a 16' 7,000# tandem trailer for about a year with no trailer brakes with a 2002 F250 7.3 and had no problems stopping it, ever. I now have a 20' 10,400# tandem trailer with brakes and to be honest, I don't really feel all that much difference in stopping, even in an emergency situation. I get that trailer brakes are safer and all things being equal, I'd rather have them but, for me anyway, they haven't made that much difference.
And yes, the brakes work, I can stop the truck with the brake controller when the trailer is attached. I think it's just that I have a 6500# truck and the trailer/tractor combo simply isn't enough to really push it around.
   / Do I really need trailer brakes? #25
When we first got our NH TC40D with BH and FEL on a 22' trailer - the trailer had brakes but my Titan truck did not.
Do yourself a favor, get the brakes. AMEN double, not only your life but others too
Just curious ..... the MH axles don't have brakes? I know MH's here have brakes on them.
I used to do a lot of modular building work where all the modules came in on temporary attached axles. After removing the wheels and axles the axles were sent to scrap as it cost more than they were worth to ship back to the manufacturing plant. Wheels and tires were sold cheap on Craig's list. No brakes, everything the cheapest possible, not even a flange to add brakes. The haulers carried at least 6 spare tires on rims as blowouts were common with the cheap undersized tires. WOULD you want those under your equipment trailer??
Ron
   / Do I really need trailer brakes? #26
Ron in Milne,
"Thank you! Oh, I am sorry, to answer the question about inspection, no a trailer this size does not need an inspection here in Maine. I am a licensed inspection mechanic- I don't remember how big thy have to be, but it is only the really big stuff that needs to be stickered here."
And you are asking these questions!!! Not sure I want you to insect my trailer.
Ron
   / Do I really need trailer brakes? #27
The biggest complaint I have heard about MH axles its that they are too wide so they have to be cut and welded back to the needed width. This is the main reason most people I have heard look down upon using them.
   / Do I really need trailer brakes? #28
You now understand why most semi trailers in Ohio run Maine tags on them.
   / Do I really need trailer brakes? #29
Yes. Most brake controllers have a manual lever on them. While moving about 20mph, apply the trailer brakes with the lever. If you feel the trailer pulling on the tow vehicle, you got brakes. For the breakaway, while stopped, have a helper pull the pin and step away. Then attempt to pull forward. If you feel strong resistance, it works.
   / Do I really need trailer brakes? #30
Hello everybody- I just have a quick easy question, well I think it is! I have just changed my fleet around a bit. I had a 2004 half ton chevy ext cab with a 16' 7k car hauler I used to move my L3200 on occasion. I never go far, just around my town doing small jobs. The truck did not like hauling the tractor, and stopping was not good either- So anyway, I sold my car hauler and picked up a pretty nice 18' deckover with mobile home axles. The trailer was well built, and down the road I will probably buy some new axles for it, with brakes. It does not have working brakes now. I dont know what the trailer weighs, but it is built pretty heavy. I just bought a super nice, 2004 Dodge Ram 2500 with a cummins diesel, 66k miles. Clean florida truck. I have not picked the truck up yet. I am wondering, do you guys think it will stop ok? I know, I should have trailer brakes, but for this year I would like to run what I have and give my wallet a break! Like I said, I might tow it 20 miles max, L3200 with a backhoe... I sure do appreciate all your advise. You all have been great in the past!
RonnieMaine,
As a former over the road truck driver, if I remember correctly, USDOT regulations state that if the weight of the trailer AND cargo is over 1,500 pounds it is REQUIRED to have brakes. They can be electric, hydraulic surge, or air, depending on how the tow vehicle is set up. :2cents:
Dave
New/Unused Quick Attach Pallet Forks (A54865)
New/Unused Quick...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55302)
Michelin CARGOXBIB...
2008 CAT D6T DOZER (A55745)
2008 CAT D6T DOZER...
(2) SQUIRREL CAGE FANS (A54757)
(2) SQUIRREL CAGE...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A55851)
2024 Wanco...
