Do I really need trailer brakes?
   / Do I really need trailer brakes? #31
I used to do a lot of modular building work where all the modules came in on temporary attached axles. After removing the wheels and axles the axles were sent to scrap as it cost more than they were worth to ship back to the manufacturing plant. Wheels and tires were sold cheap on Craig's list. No brakes, everything the cheapest possible, not even a flange to add brakes. The haulers carried at least 6 spare tires on rims as blowouts were common with the cheap undersized tires. WOULD you want those under your equipment trailer??
Ron
No that's NOT what I would want under my trailer...
Good thing that's NOT how most MH axles are built, at least not the ones under the MH delivered here...
NOW, the tires, that's different, as they really are low quality, but my tire guy sells brand name excellent tires that fit the stock rims, and "that's" how you fix that problem.
SR
   / Do I really need trailer brakes? #32
Good enough. I will see about some brakes. These axles do have brakes, but all need to be replaced. I may do away with the old mh style spindle and weld on the standard style used commonly today so brakes are easier too get. ---------------
You may not have to change the spindle: Parts for Lugged Hubs on a Mobile Home Axle with 15123 inner and 2588 Outer Bearings | etrailer.com
These fit some MH axles.
   / Do I really need trailer brakes? #33
I have same tractor, with loaded tires, and same size trailer. I can totally feel that trailer and tractor if I don't have my brake controller set right; I can stop it, but it takes longer and more pressure on the pedal. I always check brakes, since I tow 3 different trailers, to make sure my controller is set right.
I've had to make a couple hard stops to avoid accidents, mostly from people cutting me off. No way I would have made same panic stop in time without brakes, even with good brakes on my 3/4 ton turbo diesel.
I could even feel similar weight Bobcat on same trailer pushing my buddies F450 when I towed with it when the controller was not dialed in.
I towed my TC40DA on a 16' 7,000# tandem trailer for about a year with no trailer brakes with a 2002 F250 7.3 and had no problems stopping it, ever. I now have a 20' 10,400# tandem trailer with brakes and to be honest, I don't really feel all that much difference in stopping, even in an emergency situation. I get that trailer brakes are safer and all things being equal, I'd rather have them but, for me anyway, they haven't made that much difference.
And yes, the brakes work, I can stop the truck with the brake controller when the trailer is attached. I think it's just that I have a 6500# truck and the trailer/tractor combo simply isn't enough to really push it around.
thank you for that link xfaxman! appreciate you taking the time to post that!
   / Do I really need trailer brakes? #35
Your're welcome. They are available from several places, just do a search.
   / Do I really need trailer brakes? #36
My experience.
Buddy loaded my PU (3/4 ton GMC 4 x 4) and my trailer with top soil that my wife wanted.
As I neared the first stop light I downshifted and braked then decided where I would crash the truck to cause the least damage.
Luck was on my side and the light turned green and fortunately the other vehicles accelerated rapidly letting me clear the intersection.
FYI, the rest of the trip home was VERY slow and timed to clear lights with lots of horn honking.
Never again.
He loaded me 'till the springs showed signs of sagging. (both truck and trailer had HD springs)
That PU diesel never even hinted of straining. (bet I could light a cigarette on the brake disks)
   / Do I really need trailer brakes? #37
Ronnie: Glad to hear you are adding brakes to this trailer. My advice is do not ever even think about hauling your tractor on that trailer with out brakes. If that trailer breaks away from your truck for what ever reason and that trailer hits someone and kills them you will go to jail
You are absolutely right Mikesee. I never thought that deeply into it. I would not want anyone getting hurt on my conscious, that alone is reason enough....
   / Do I really need trailer brakes? #40
I have trailer brakes on all 3 of my trailers over 4000 pounds GVWR. My 03 GMC has 210,000 miles with factory brakes still on it. Just had new front hubs and rear seals done and all four brakes have over 50% pad left. To me that justifies having good trailer brakes.
JOHN DEERE BA84 WORKSITE PRO ANGLE BROOM (A54757)
JOHN DEERE BA84...
Television (A53425)
Television (A53425)
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2016 Toyota Prius Hatchback (A53424)
2016 Toyota Prius...
Scotsman Commercial Ice Machine (A53425)
Scotsman...
