Do you grease your balls?
   / Do you grease your balls? #11
firemanpat2910 said:
F W J say it isnt so, using a coupled connection for a ground is not the best way to do it. Now if your saying its a backup ground, then you are correct. I have fixed more than my share of trailer problems over the years and at least 75% of then are ground related.
More like 90%....
I never use a wired ground. Never have never will most likely. No issues with hitch as ground.
   / Do you grease your balls? #12
I do it every so often and take the hitch toungue out after every use. To keeep it from getting grease all over the truck, I keep the tongue in a tube like cut off piece of jeans. Works like a charm.
   / Do you grease your balls? #13
NEVER !!! ......................... Tends to make seat slick.
   / Do you grease your balls? #14
not to hijack but since you mentioned pulling the drawbar from the reciever, I used to haveto do it at least twice a year to keep them from rusting shut, now I have an aluminum draw bar and it works great.
   / Do you grease your balls? #15
Farmwithjunk said:
More like 90%....
Maybe its the weather or something but I never have any luck with out the white wire properly grounded on both halves but hey if its gotten you this far who am I to say its not right, Shouldnt you be out mowing something??:D :D
   / Do you grease your balls? #17
We grease the hitch balls with moly wheel bearing grease. Seems the most appropriate. Yes, it can be messy, but I prefer not having stuff wear out or rust out. None of our hitch balls were chrome to start - I think they were zinc chromate, which is not as slick. We remove the receiver hitch ball when not in use. The gooseneck hitch ball (remove-a-ball style) either gets stored in a plastic bag in the cab, or we tie a plastic bag over it when not in use.
I don't think grease is essential for light trailers weighing maybe 1000lbs and with a 100lb tongue load. With gooseneck or 5th wheel hitches, or a highly loaded receiver hitch, I think it is mandatory. Note that all semis have their 5th wheel hitch thoroughly greased, and that grease is removed and replaced on a regular basis.
   / Do you grease your balls? #18
Yes, when I was doing landscaping, I put grease on the ball several times a year. The trailer with mowers and other equipment, was hooked up 27/7 with lock.
   / Do you grease your balls? #19
27/7 !!! WoW you guys in Florida sure do work long days!
jb
2014 CAT CT6 (A55745)
Wacker Neuson DT08 (A53314)
Wacker Neuson DT08...
Giyi Root Grapple (A53316)
Giyi Root Grapple...
2016 Chevrolet Tahoe SUV (A55758)
2016 Chevrolet...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A55787)
2025 GIYI GY-PG72C...
