Do you grease your hitch ball
   / Do you grease your hitch ball #31
I also lube the socket as it keeps everything moving freely. You can always wipe your balls off after use.
Learned that at age 17 .
Excellent advice !!!!
   / Do you grease your hitch ball #32
Why not fix the ground wire on your trailer lights? Then it won't be trying to ground through the hitch ball?
Aaron Z
Ground wire? Aren't you fancy! :) On many trailers one hot (switched) wire runs to the lights, the light's return path are through the bolt that mounts them to the frame.
Yes, on one of my trailers after a decade or two of owning it, I replaced the wiring connector on the trailer with one that had a short white wire stub that I drilled and tapped a hole for on the trailer tongue.
   / Do you grease your hitch ball #33
   / Do you grease your hitch ball #36
:eek: :eek:
Anything is possible.......but are they sure they didn't have a 1-7/8" ball with a 2" hitch, and then one day the trailer coupler's "toe-plate" (or whatever it's called) that goes under the ball wore down, or got loose enough, to pop off the ball? A 1-7/8" ball will work on a 2" hitch most of the time...until it doesn't.
I'm hesitant to put any dielectric, like grease, on the ball hitch as I'm often relying on good metal to metal contact for the negative ("ground") return path back from my trailer lights. Heck, sometimes it takes a few miles of going down the road and making turns to wear the rust off before the lights work if its been sitting for the winter.
Re-wire your lights. The trailer light connector has a dedicated ground that does not depend on the trailer hitch. Yours is corroded or broken.
   / Do you grease your hitch ball #37
I regularly spray some grease into the hitch socket. I don't worry about the ball but I don't leave it on the truck when not in use. Electrical grounds are a minefield. I hard wire all the grounds AND ground to the frame of the trailer and truck.
   / Do you grease your hitch ball #38
I use regular axle grease on the balls and couplers both. I keep the ball mounts in my toolbox with an old cut-off sock over the balls, works great.
   / Do you grease your hitch ball #39
I just give the top of the coupler (in the lock down lever) a shot of PB Blaster once and a while. Makes a big difference in the ability to lock it down and I think it leaches into anywhere it should go.
   / Do you grease your hitch ball #40
I tend to fix the things that don't work. I really don't have the time to fix the things that do.
(4) Firestone 380/90R46 Tires & Rims (A57148)
(4) Firestone...
2022 Bobcat 68" Bucket Grapple (A57149)
2022 Bobcat 68"...
UNUSED SDLANCH SDLC2030FT 20' X 30' CARPORT (A58376)
UNUSED SDLANCH...
2014 Kubota R520S (A57148)
2014 Kubota R520S...
Giyi 72" Grapple Bucket (A57149)
Giyi 72" Grapple...
2007 Kubota B7510 (A57148)
2007 Kubota B7510...
