Zebrafive
Super Member
I would not have beleived that you could do it but I did. --My dad called and asked me to look at his car not starting. --sure no probelm, I was a trained diesel mechanic at the time. Went over to his house and his 1978 oldsmobile had a dead battery. ---told him i would take it home with me and charge it up and bring it back in the morning. ---must of been a little tired because I hooked up the charger backwards and because the battery was so dead it din't spark or short out. -- Well I charged up the battery and I put it back in the car and it would turn over fine but not start! Had the hei ign system and I checked for a spark and had none. ---Well now I get out a volt meter and start to check things and find that my analog volt meter wants to bottom the meter backwards. --This was 30 years ago,--I remove the battery terminals and check the voltage with the meter hooked up backwards and it dawns on me that the battery is charged up backwards ---- Took the battery back home and hooked up a headlight on it overnight to drain it. Then recharged CORRECTLY! --- Then I loose some sleep thinking of all the things that will be burned out or not work. ----Put the battery back in and it started and ran fine. -- No other problems. --Still seems strange that it turned over but i guess the starter din't care about polarity. --DUMB!
I wonder if it had started, would it be running backwards?????
