Do you like your R4 tires?
   / Do you like your R4 tires? #31
Good to know. I was basing my comment on a discussion I had with a dealer. I'd be willing to bet that those front tires base diameter are the same as the base of the normal turfs that would have gone with it. I guess I should not say always, just be careful if you do go that route.
I am sure they are as my father in law bought it new that way. We have replaced the tires once and they were ordered from a local dealer. I was kind of skeptical when he got it being from a farming background, but it works really well especially in the woods and on slopes.
If we ever have to replace them, I don't know if we will keep it that way or go with Ags. We don't use it much anymore, so my kids will probably be the ones to make that decision.
   / Do you like your R4 tires? #32
I'm wanting R1, agri, tires. However the dealer only has R4, industrial, tires on the tractor I want. He is going to try and find a set of agri tires to swap out with before I show up Saturday. In the event he can't I have to decide what to do. How do you like your R4 tires? Ever wish you had R1's?
Maybe too late to answer if you had to go in today...
Anyway, YES the R4s on the front are pretty much NEEDED if you use the FEL, and on the rear will take a lot more liquid ballast than R1s.
They also "float" in some muck that R1s "cut" into and rut - think ground pressure, etc.
   / Do you like your R4 tires? #33
You can't mix and match, the actual base tire diameters minus the tread need to be matched accordingly. The tires and wheels are different sizes from any of the types to the other. They are very specifically designed for their matching front and rear. On a 2WD would not matter, with the 4WD your tranny and gears will be toast in no time.
That depends on;
a) Whether the tractor has fragile gears/trans.
b) Whether you run it in 4WD on hard (good traction) surfaces.
I can't see a case for buying a tractor with fragile gears and trans, neither can I see a case for running in 4WD where traction is SO GOOD that it will take out even a fragile trans.
Up to 5% LEAD is good, just about ANY lag is BAD - the rear tends to go faster than the front, so steering a straight line becomes difficult.
   / Do you like your R4 tires? #34
   / Do you like your R4 tires? #35
That depends on;
It is not about gears being fragile. There is no equipment that is designed for one axle to be working against the other. Simple physics. If you are on hard surface especially you see the result that much faster. There are some allowances for any setup for tire wear but even then the base diameter stays the same and that is where the tractor does its work.
   / Do you like your R4 tires? #36
........................ I got a 2010 Case Farmall 45 HST with FEL for $22,560. I thought that was a pretty awesome deal.
Congratulations on the new tractor. 22500 is a good price for a new 45 hp HST tractor/loader combination in any color. I personally prefer red over blue. Enjoy!
   / Do you like your R4 tires? #37
Sometimes I think ag tires would be be good. I've heard they have the best traction compared to the industrial and turf tires. But they also do the most turf damage. I wonder if people sometimes change the front tires to ag and keep the rear tires industrial? When I get my new tractor in a few months i was thinking of doing that. To me it would make since have the ag tires on the front. ecspecially if your doing loader work.
   / Do you like your R4 tires? #38
You can call it simple physics - I prefer to call it design parameters.
4WD tractors ARE designed for the front wheels (at the circumference) to turn a few percent faster than the rear.
This is a very desirable attribute.
Weights and loads are KNOWN, coefficients of friction between surface types are KNOWN.
It is POSSIBLE to design and manufacture for anticipated forces (& uses) in fact it is necessary to do so.
On hard surfaces the forces build up until the tire/road friction is overcome, typically quite suddenly - known colloquially as "wheel hop".
Tractors and other 4WD vehicles DO THIS and they DO SURVIVE - at least the adequately engineered ones do.
It is impractical for someone, for example moving snow, to shift out of 4WD every time they come out of a driveway and get back onto dry road to make a tight turn and go back in. Similar situations exist in the fields, though not so obvious and the changes in traction are not so extreme.
I have taken the occasional local "road trip" to neighbors' places and noticed at some point that the tractor is humming along in top gear and still in 4WD - no toast, no mechanical noises, no drama, no damage.
Again, adequately engineered tractor transmissions and axles CAN and DO take 4WD use on hard surfaces - though tire wear is likely accelerated.
I don't suggest or recommend this, but I don't live under a delusion that parts are going to suddenly fail "in no time".
I maintain that anything unable to take this is poorly engineered and/or manufactured - in a word "FRAGILE".
   / Do you like your R4 tires? #39
I think that would be exactly the wrong way around (-:
If you BELIEVE that R1s have better traction than R4s and that R4s have higher load rating;
R4s on the FRONT for loader use.
R1s on the REAR for traction.
Although you would be passing up the opportunity for 40+ % more liquid ballast in the rears.
I happen to "believe" (without incontrovertible experimental "proof") that the extra ballast and lower ground pressure result in a lower probability of rutting, i.e. loaded R4s CAUSE less damage of the sort that R1s MIGHT get you out of.
One configuration I saw a couple of years ago was "racing slicks" on the front of a tractor used for building/re-building baseball fields.
I talked to the guy and it seemed to make a lot of sense, he gets them for free when they are too worn to race on.
I forgot the size, 15 inch rims and very wide - he probably had turf tires on the back.
Just remember that baseball diamonds are pretty flat and although they spread and work on clay - your terrain may be very different and probably is (-:
In any case turf damage is more about tight turns on wet turf than tread pattern (-:
   / Do you like your R4 tires? #40
I never said that running a tractor on hard surface with 4WD was not to be done. What I said was that you need to make sure the corresponding tires on the front correspond to the rear. If you switch from on tread pattern on front different to the rear you need to make sure those sizes still correspond. That is plain and simple. Often times the sizes from one type of tread to another changes the tire diameter or original size. Example of R4's to R1's are often the case of difference in size/diameter. No machine is designed to handle that mixing and matching. I drive my 4wd tractors on hard surfaces in 4WD without issue and don't think second about it. The OP was talking about one type of tread on the front and a different type of tread on the rear. Once again, plain and simple, if those tire types are the same diameter of the base tire than you are okay. Why don't you put a tire and/or wheel of completely different size on your front or rear and leave the other in place and prove me wrong or have fun changing your tranny and/or gears.
New Holland 650 Hay Baler (A53317)
New Holland 650...
2019 Doosan LCV6W Towable LED Light Tower (A55851)
2019 Doosan LCV6W...
Metal Bigfoot Lawn Art (A55853)
Metal Bigfoot Lawn...
Two Pairs of 10ft Fork Extensions (A53421)
Two Pairs of 10ft...
2025 Swict 60in Bucket Skid Steer Attachment (A53421)
2025 Swict 60in...
Husqvarna Z 248F 48in Zero Turn Mower (A55851)
Husqvarna Z 248F...
