Do you like your R4 tires?
   / Do you like your R4 tires? #41
I never said that running a tractor on hard surface with 4WD was not to be done. What I said was that you need to make sure the corresponding tires on the front correspond to the rear. If you switch from on tread pattern on front different to the rear you need to make sure those sizes still correspond. That is plain and simple. Often times the sizes from one type of tread to another changes the tire diameter or original size. Example of R4's to R1's are often the case of difference in size/diameter. No machine is designed to handle that mixing and matching. I drive my 4wd tractors on hard surfaces in 4WD without issue and don't think second about it. The OP was talking about one type of tread on the front and a different type of tread on the rear. Once again, plain and simple, if those tire types are the same diameter of the base tire than you are okay. Why don't you put a tire and/or wheel of completely different size on your front or rear and leave the other in place and prove me wrong or have fun changing your tranny and/or gears.
Your posts are inconsistent, as in;
"...with the 4WD your tranny and gears will be toast in no time"
vs your last post.
So, what a dealer told you, simple physics, anecdotal evidence, or do you REALLY KNOW what you are talking about ?
I am quite content to run with a few percent lead.
Thanks anyway, but I do not need to explore the extremes of your suggested ridiculous experiments.
If you want a more reasonable "experiment", run straight ahead in 4WD slowly for a short distance and see how easy it is (or isn't) to disengage 4WD.
This should show that there is tension between the front and rear, i.e. a slight lead/lag.
Keep pulling gently on the 4 to 2 WD lever and initiate a turn.
What SHOULD happen is that the lever shifts quite easily from 4 to 2 when the few percent greater travel of the front axle around the curve matches the front axle lead.
According to the exact lead you have you may have to tighten the turn, the point is that at some radius it should match.
If you have to turn to max lock before the tension releases then you have too much lead.
(IMO, since I have never made PRECISE measurements for this, "my experience has shown", etc.)
If it does not release then you may have lag, but another symptom of that is difficulty keeping a straight line in 4WD, i.e. a tendency for the tractor to wander or actually turn if you take your hands off the wheel.
Mayhap this helps ?
GENERALLY Cat 1 and Cat 2 tractors offered with alternate tire SETS will have rolling circumferences that are fairly close to each other.
The R1s with be on larger diameter rims than R4s, which in turn will be on larger diameter rims than R3s, but the wider and higher profile of the R4 results in a similar rolling circumference - same with Turfs, there isn't THAT MUCH difference in rolling circumference.
Certainly not enough to toast a tranny and/or gears in no time.
I suspect that there are exceptions to this generality, but it is foolish at best to take the pathological case as typical (-:
   / Do you like your R4 tires? #42
vs your last post.
Mayhap this helps ?
Try actually reading what I wrote and not what you wanted to turn it into by taking it out of context would help to start. There are enough differences at "times", not all, in rolling circumference in what I state BETWEEN TIRE DESIGNS. You can choose to make a broad sweeping generalization if you want about fragility but checking and making sure that there really aren't any differences costs a lot less than relying on YOUR word that it is all true and safe. May be you can afford to experiment or one can just do a little checking and/or math and not have to worry it. Nothing pathological about that, anecdotal or ridiculous, just common sense. But I have found that Common sense is not so common and you have helped me to validate that.
   / Do you like your R4 tires? #43
Right,,,
I do check tire size relationships before changing sizes or types, typically at FirestoneAG web site, here is a CUT link;
Firestone Agricultural Tire Division | Compact Tractor Tires
and the general Ag tires link;
http://www.firestoneag.com/agricultural_tires.asp
there are other useful links around the site, e.g. on fluid ballast, capacity of tires by size, how to fill duals to 40%, singles to 75% etc.
By looking up the tractor manufacturer's standard offering one can impute the front/rear ratio, which is typically somewhere around 1:1.6 for CUTs.
If they offer more than one standard tire you can check the ratios of those too, but the R1 is most likely to have the best lead.
{Due to commonality of parts (& integer quantities of teeth on gears) there is a limited number of ratios available.}
From that you can pretty much pick whatever tires you want, although you should AVOID lag and it is probably unwise to pick more than a couple percent above the standard lead.
This has worked out for every tractor I have bought and every tire set I have changed to, as well as a few that I have considered.
Obviously I have not checked EVERY tractor on the market (new or used), but those that I have checked have been consistent.
If you want to know ACCURATELY what your front/rear ratio is you can do that in 2WD on a short section of straight road.
Just mark the tires against the road where you start and have someone drive forwards slowly while you count the tire revolutions.
Get as many as you can on the rear tires and estimate the fraction of the last revolution on the front as best you can.
Do it all again in 4WD and you can figure your current lead/lag.
This is good to know, since if you ALREADY have a lot of lead you wouldn't want to increase it further, OTOH if you have only 1% then a little more would be better.
Don't worry, the trans/gears won't get toasted (-:
   / Do you like your R4 tires? #44
Right,,,
Firestone Agricultural Tires
Everything you just said, in its entirety, I agree with completely. Thanks for the verification. My point to start was to use caution and reading your last post indicates to me your above mentioned approach uses that caution. I would say that overall we are on the same page, just different ways of expressing it. :)
   / Do you like your R4 tires? #45
i have had R4's on my last two CUT's.i use my machines for general purpose,mowing,loader type work.if you are going to be doing field work,yea,the R1's are the way to go,but if you are Harry Homeowner who needs general purpose,the R4's are the way to go.if you are going to be doing nothing but mowing,the turf tires are the obvious choice.i have read before that guys like the turf's for snow removal,IMO,i wouldn't try it unless i had chains for sure.i need chains on my R4's for snow,but for everything else i do,they work great.just depends on what you are going to do the most with it.the R4's are a compromise tire.best of both worlds i think,JMO.i have plowed with them and don't have a problem.i like the fact they have a heavier sidewall because i am into alot of rocks and rough stuff,my ground is loaded with shale.it was just the right choice for me.at 300 hours,they still look great outside of some slicing on the tread from spinning because i don't have chains to use in the snow ,yet.on my hill,i don't think the R1's would do any better in the snow,steep grade,off camber,gets scary at times ,,,,,,,,
   / Do you like your R4 tires? #46
I like my R4s alot. I mostly mow wth my Massey 1533. Some ground work and snow plowing. In the snow I added cahins to he front wheels to be able to scrape up hill. Works great.
   / Do you like your R4 tires? #47
I have a new L3800 HST Kubota with FEL and R-1 tires. Rears are loaded with Rim Guard. My previous tractor was a Kubota B3200 with FEL and loaded R-1's. All the tractors I have owned before these 2 had R-4's. I love the traction advantage that the R-1's provide over the R-4's for my use. The yard damage is more with R-1's if I need to get on it but that is a trade off I can live with. I do however wish I could get R-1 tires in the same exact size as the optional R-4's so I could have the killer traction of the R-1's and the superior floatation of the R-4's. That would be my perfect tire.
   / Do you like your R4 tires? #48
I'm wanting R1, agri, tires. However the dealer only has R4, industrial, tires on the tractor I want. He is going to try and find a set of agri tires to swap out with before I show up Saturday. In the event he can't I have to decide what to do. How do you like your R4 tires? Ever wish you had R1's?
I've had a series of compact tractors and have tried R1, R4 and turfs on most of them. It is critical to match the rolling circumference carefully for 4WD. The tire you choose depends on your own soil and what you want to do with it. Ag tires give the best traction in soft or muddy soil but leave a footprint deep in the soil and anytime when turning. R4 and Turf type tires do offer improved side hill stability - and depending on the tire they can also lower the center of gravity. So that might make a difference to you.
My land is rocky overlain with disintegrated granite. The soil is thin and grass is delicate. R1 isn't any advantage here, in fact it has less traction than other profiles. R4 is a decent compromise and durable, and does has enough bite to work in snow without chains....but the stiff sidewalls and sharp edge to the tire tread still tear up the soil a bit when turning.
rScotty
   / Do you like your R4 tires? #49
I have R4's on my 2100-lb CCY, and so far I've used it with a 700-lb 6' finish mower to mow a fairly flat piece of property overlain with silt loam soil and Bermuda turf. I removed the FEL for mowing, and I haven't seen any damage to the grass after several mowing sessions. However, I've noticed the front tires do cause divots when I turn the wheel while stationary or moving at very low speed, but that doesn't happen if I turn the wheel while under way. Traction is very good, though the rear tires do sometimes break loose if I try mowing at a crawl while on a slight incline. I don't have weighted tires (to minimize turf damage) so engaging 4WD at such times cures the traction issue. The R4's also performed well during what little FEL work I've done so far, but it remains to be seen how they perform when I plow snow off my 150-yard paved driveway this winter.
   / Do you like your R4 tires? #50
I also have had both and chose r4 's with my current tractor as we have lots of briar bushes in my neck of the woods and they don't penetrate through the r4's nearly as easily due to the tougher rubber. I pull a 3 bottom plow with the kubota 5700 4wd with no problem and have no issues in the snow either. My neighbor will get a flat once in awhile with his r1's due to the briars. I have yet to get a flat with these r4's and very happy with them. I use the tractor for garden work, getting wood and mowing fields.
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2004 Saturn VUE SUV (A55853)
2004 Saturn VUE...
2005 Tennant ATLV 4300 Turf Vacuum (A55851)
2005 Tennant ATLV...
