Do you lube your 3-Point linkages?
   / Do you lube your 3-Point linkages? #1
Danner
Kubota BX2660
You know, the pins and swivels. I'm torn between the confidence of a well oiled machine and the fact that oil/grease are dirt magnets.
   / Do you lube your 3-Point linkages? #2
That is a good question. I never have, nor have I ever seen anyone who has, but I am not in a huge agricultural area. I would be afraid of the dirt attraction. I have never seen any signs that the pins or ball joints have worn unduly.
   / Do you lube your 3-Point linkages? #3
My Deere manual says to oil them and I do. I've seen the freeze up without oil. Yes, you will need to clean the dirt the oil catches before you oil them again.
   / Do you lube your 3-Point linkages? #4
You need to use some older well used tractors then :laughing: I know I need to replace a few parts on mine as the holes are nice and long.
   / Do you lube your 3-Point linkages? #5
Never. They MIGHT sieze if not used for extended periods of time. Normally used, they'll never seize. Lubing the pins serves no purpose, other than greasy hands.
   / Do you lube your 3-Point linkages? #6
I spray some white lithium grease on the balls. It doesn't seem to attract much dirt.
   / Do you lube your 3-Point linkages? #7
I do. I spin the balls so they are 90 deg. to normal or so the eye is facing front to back and I try to get the grease up inside the socket. I use wheel bearing grease. When done I line everything back up for normal use and wipe off the excess grease. Don't know about long term effects, but I will probably continue this. I only do it maybe once a year or less.
   / Do you lube your 3-Point linkages? #8
Nope and we have some tractors built in the 50's and 60's with no visible harm.
   / Do you lube your 3-Point linkages? #9
I've been on plenty of older well used tractors, and the components looked to be in good shape to me. Maybe you can destroy an anvil with a feather? :D
My experience is regional, and I think some of the farmers out west work the snot out of their tractors with huge crops and extremely long work days. I defer to them.
   / Do you lube your 3-Point linkages? #10
There was just a post about this somewhere on this site. The vast majority of responders use a dab of extra grease smeared on the balls and pins. I do the same.
JayC
2011 KENWORTH T800 SLEEPER (A50854)
2011 KENWORTH T800...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
2000 Ford F-650 TMA Attenuator Truck (A49461)
2000 Ford F-650...
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
