Do you lube your 3-Point linkages?
   / Do you lube your 3-Point linkages? #21
How old does your equipment have to be before you grease your balls? Plus if you use any sprays it tends to burn a wee bit.....
Wow, good thread, funny innuendo too :D
Good ideas. It turns out I have some bicycle chain dry lube, and that seems like a pretty good choice, all things considered.
You guys are great :thumbsup:
   / Do you lube your 3-Point linkages? #23
:eek:Well, I'm staying out of this thread.:eek:
   / Do you lube your 3-Point linkages? #24
I vote for no grease. I am not a heavy tractor user but if there was grease all over my 3 pt hitch and attachments I would be scared to walk in the barn for fear of coming out covered in grease. Even with my limited use my balls stay rust free. Yes I am married with a couple kids.
   / Do you lube your 3-Point linkages? #25
You know, that is a good point. I grease, then I wipe things down, and I still get grease on me. If I did that to the 3pt, I'd be a mess all the time.
Still curious what the BIG DOGS (Mid-West farmers farming 1000's of acres) do.
   / Do you lube your 3-Point linkages? #26
May I suggest spray graphite. I use the stuff JD labels for slip clutches anywhere you need lube(but not bearings of course). It works great. It does not attract dirt or dust, and after a few uses, seems to impregnate in the metal and reduce or eliminate oxidation. I have been using it on the top link, balls, and pivot points on the tractor with no problems. It also works wonders on hinges, gates, squeaky leaf springs, etc.
I tried dry film lubricant but it doesn't seem to work as well or last as long. I use the graphite maybe once a year on tractor and equipment and it lasts all season.
Spray it on but let it flash off before moving the parts.
   / Do you lube your 3-Point linkages? #27
Don't grease thing's! If you do I might be out of a job!
On a serious note the reason we sell so many moving parts, pins and balls included is because people believe greasing things is bad?????
If you own a grease gun and know how to use it then you can own a tractor. If you don't then don't by a tractor. Tractors need grease as much as they need diesel, you can never have to much grease. Tractors are also dirty machines ( yes even the ones that get polished) so if you don't grease a tractor because you are worried about getting dirty don't come crying to me about having to keep replacing parts!
   / Do you lube your 3-Point linkages? #28
Boy...there are a number of posts on this thread...well, if those posters ever end up in prison together...at least they won't be lonely (or bored).
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
23311 (A51694)
23311 (A51694)
2003 Mack CH613 T/A Day Cab Truck Tractor (A52377)
2003 Mack CH613...
20" Sea Container (A47384)
20" Sea Container...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
John Dozer JD650 (A51691)
John Dozer JD650...
