Do you replace antifreeze?
   / Do you replace antifreeze? #31
I do not have a home kit. I have 2 TDS meter (electronic) and someothers and some waters are high in TDS. I even ran the best bottled distilled water I could find with only 32 ppm of TDS and it was junk. It (high TRDS) effected my PH, ALK, DKH, Ca and Mg like mad.
Distilled should be pure as can be but you do not know how it is distilled. So far the best is 32 ppm TDS. To high for me. I even want to our local food store and walmart and got there distilled water. They were over 55 ppm. The max per FED rules is 500 ppm so the 55 ppm is very low, but not good enough for me.
So far distilled is not good enought for me...as the meters have shown.
   / Do you replace antifreeze? #32
Distillation of water differs from other forms of water purification (reverse osmosis, deionization, etc.) because water is removed from the impurites rather than the impurities being removed from the water. Water undergoes a phase change during distillation, changing from a liquid to a gas and then back to a liquid. It is the change from liquid to vapor that prompts a separation of water from its impurities.
Impurities with a boiling point higher than 212*F (100*C) remain in the boiler. Water and impurities with a boiling point equal to or lower than water are converted into water vapor and condensed in the final distilled water.
Distillation removes most inorganic sollids, all organics with a boiling point greater than water, all bacteria, and pyrogens. Gases, particulates, and other organics cannot be removed by distillation as they undergo the same phase changes as water and therefore must be reomved utilizing other technologies.
   / Do you replace antifreeze? #33
</font><font color="blue" class="small">( I was researching how to dispose of ethylene glycol. Ain't much you can do with it other than take it to a disposal place. Not many shops will take it any more, like they will (or have to take) used motor oil. )</font>
That's really too bad. When it becomes really inconvenient to get rid of, most people will just pour it out on the ground or down the drain. /forums/images/graemlins/frown.gif
"I do not have a home kit. I have 2 TDS meter (electronic) and someothers and some waters are high in TDS. I even ran the best bottled distilled water I could find with only 32 ppm of TDS and it was junk. It (high TRDS) effected my PH, ALK, DKH, Ca and Mg like mad."
Tell me more professor!
This is getting so complicated. I think I will simplify it and go buy some hydrogen and oxygen and make my own water. Is that two parts hydrogen to one part oxygen or one part hydrogen to two parts oxygen? /forums/images/graemlins/smirk.gif
   / Do you replace antifreeze? #35
If that is what you want to buy, then so be it.
This is what I have (the combo).
http://www.milleranalytical.com/Conductivity_TDS_Meters.htm
I also have a cheaper one (around $70)
I have to watch the TDS, as again it effects my ALK and hardness, PH, calcium, and magnesium. Also TDS (Total Dissolved Solids) have silciates and phosphates. It goes deeper since my reef tank needs things and not other things, but you get the hint.
All I am saying is that if you think distilled water is pure, think again.
Here are some neat things:
My Tap around 39ppm (pretty good here)
Fridge 37ppm (filtered through a carbon block)
Kent maxxima Hi-S RO/DI 0ppm
Evian 287ppm (mud)
Dasani 31ppm (Coke says its RO with minerals added for taste)
My grocery water 153ppm
Distilled water (walmart) 44 ppm.
   / Do you replace antifreeze? #36
Not saying it is pure, but light years better than tap water and cheap and easy to get. Not many people buy water at Baker Scientific. I use distilled water for my cooling systems, unless I am in a bind/breakdown, then any water that is available /forums/images/graemlins/smile.gif
Ben
   / Do you replace antifreeze? #37
<font color="blue">( All I am saying is that if you think distilled water is pure, think again.
Ben
)</font>
I agree somewhat but is also depends where you buy the water and what kind. The walmart kind is no better then my tap water. Even my tap water has less TDS then Dasani bottled water. Now other things in tap like pesticides, fluorides, uranium, chlorine etc are a different story.
Most fish stores and some food stores will have RO water. Some also have RO/DI water, which fiosh stores will have. For the benefits of it, it is worth the small price..around $1.50 - 2. per gallon for Ro/Di water.
   / Do you replace antifreeze? #38
I'm back again, since I'm changing all fluids. I have read to use "Fleetgard" anitfreeze for diesel, but what is RO/Di water? . I need to know the proper coolant mixture items.
Thanks,Ed
   / Do you replace antifreeze? #39
Fleetguard is a great coolant. I need to go buy some myself.
You do not have to use RO/DI water but I found it to have less crap in it and better PH level. Less stuff in water the better.
RO/DI is Reverse Osmosis Deionization
   / Do you replace antifreeze? #40
<font color="blue"> I used the Super Duper Extra Believable Home Water Tester Kit I got from the internet and tested all the Classes of water out there. I researched this on the internet and it was the best testing kit out there. No scientific proof but hey the internet is better than science or actual real life experiments. It showed that the holy water was lacking in water chemicals. The chemicals it had wore out way too fast and it was inferior to Class IV waters so only Class IV water for my tractors and vehicles now </font>
I recently sent my windshield washer fluid to be tested, and I've found the brands from Walmart or Autozone are only a group 57 washer fluid, but the more expensive brand at the Exxon station on the corner is a group 63. Using the Group 63 washer fluid enables it to be recycled-- after it runs down the windshield, it runs back into the reservoir and I'm able to reuse it with 97.5 percent effectivity. I've got a spreadsheet that I found on the internet that shows even though it costs more to buy at the Exxon station, it saves me 52 cents a year!
/forums/images/graemlins/grin.gif
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
2007 Pace American Enclosed Trailer (A49461)
2007 Pace American...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
2018 PJ 40T/A GOOSENECK TRAILER (A50854)
2018 PJ 40T/A...
2005 MACK CHN613 WINCH TRUCK (INOPERABLE) (A50854)
2005 MACK CHN613...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
