Dodge Cummins Engine Concern
   / Dodge Cummins Engine Concern #181
So what is the reason? Space considerations preventing a large single battery that would essentially be 2 series 6s. The 6V battery is being supported in less and less variety.
,,,.Youre right ... Theres no debate that a larger number of cells [12 vs 6 cells] presents a higher number of potential failure points. And one weak cell in a // system takes down both batts.
One bad cell in a series system results in an immediate no start. Simply not the case with a parallel system.
Read this thread:
Viewing a thread - Two 12 v batteries vs two sixes volt series&highlightmode=1#M3732771
And I admit to a mistake; IH abandoned 6V batteries in series in the late 1970's.
   / Dodge Cummins Engine Concern #182
Read this thread:
Thanks for the link. [You may want to delete the 2nd of the double post.]
,,, Gerald J in the linked thread develops the issue credibly. -- 12V batteries are fresh and there is a plentiful variety to choose from. Its unlikely to find 6V fresh, and certainly not with the newest insulator and plate technology. I was wondering at the lack of reliability thats reported. ... An unfortunate development because the series setup is inherently superior.
,,,,This is due not only to fewer parts to fail, but to the same current flowing in each cell. This equal treatment favors an equal charge in each cell, equal charge cycling in use, and more stable aging.
,,,,A cell can fail in several ways. The most usual is a continuous increase in its internal leakage current due to breakdown of insulation between its plates. Sometimes this happens very quickly, but usually the increase is slow. The effect of the leakage, of course, is to discharge the cell. -- The good/best cells discharge about 5% a month - the one going bad discharges way faster. Still, with a standard battery configuration [a series string of 6 cells], when a vehicle is used every day the degradation wont be noticed subjectively until the bad cell has discharged to about half during the interim between starts. Then you might notice the crank slowdown just as the engine catches. Time to pay some close attention to that battery.
With the parallel setup there are 2 series strings of 6 cells working side by side. Currents from and to each side are different. Both sides suffer from this. This fact affects longevity, but in actual practice remains "in name only" until a cell in either of the batteries falls off its nominal performance. The bad going cell causes the battery its in to siphon power from the good batt at all times. ... It gets the majority of the charge, and then when the engine is off it sucks power from the good battery to keep itself charged. The healthy/suffering batt camouflages the developing failure longer than would be the case for a single large 12V batt with a cell going bad.
,,,,So, if you miss the signals from each of the different setups- how bad is the startup issue when it bites? Both systems have a "dead"/discharged cell. The 6 cell system has 5 charged cells. ... The 2 x 6 cell [parallel] system has 5 charged cells in the battery with the "dead" cell. The battery connected to it has the same voltage because it has been keeping it charged. It is a 12V healthy batt that has been discharged to ~10V. Its essentially dead. No help for a start there.
The 1 x 6 has 5/6th of its charge whereas the 2 x 6 has just 5/12th of its charge.
,,,Which would you prefer to jumpstart?
larry
   / Dodge Cummins Engine Concern #183
larry
I perfer that vehicles and equipment that I own and am responsible for do not require jump starts.
   / Dodge Cummins Engine Concern #184
I would like to add a couple thoughts to Spyderlks comments,
Batteries fail generally in one of two ways: not counting old age and sulfation
1) short- a cell becomes a straight electrical path with no ability to store a charge, , but does have the ability to carry full current when the bad cell is in series with good cells - so a 12 volt battery will have aprox. 10.5 volts- but if used to spin a starter will still work although at reduced speed .
The other effect is it will work the heck out of the alternator-trying to bring the voltage up to around 14 volts and the battery will sweat excessively and out gas from the good cells being overcharged.
2) open cell - the cell is capable of holding a surface or even full charge , but because the internal series connection of the cell to other cells in the battery has failed or been degraded , the battery may show a full charge (voltage) , but when load tested will not be able to provide virtually any current.
I agree that paralleled batteries are more likely to have concealed problems as Spyderlk stated, one preventative measure that can be used- is to check the batteries independently with a load test periodically. my:2cents:
   / Dodge Cummins Engine Concern #185
Concealed problems allow a vehicle to start. Overt problems don't.
You both can argue against current manufacturing practice AND the proactive actions made by countless machine owners by investing in conversions away from series battery installations.
I'm wondering how many machines either of you own with multiple batteries connected in series?
In any event, I'm done with this discussion because at the end of the day I don't care if anyone is convinced that one way is better than another. I know what my preferences are.
   / Dodge Cummins Engine Concern #186
Personally-I prefer parallel 12 volt systems and have changed over 1 tractor (rhino) from series-ed 6 volts to the paralleled 12 volt and my Dodge cummins came that way.
I am in no way advocating 6 volt series-ed systems - and cost savings alone make the 12 volt parallel set ups preferable to me.
   / Dodge Cummins Engine Concern #187
FWIW, I have an 06 model for sale... but it aint gonna be cheap.
   / Dodge Cummins Engine Concern #188
Zero. I go to the highest performing 12V batt available and use it singly. 1000CA suffices for everything including the Dodge 5.9 Cummins down to 0F. Prior to that I had 2 failures of 2 batt paralleled systems in the Dodge over a 6yr period -- both a surprise no start. Now on the 3rd yr with the single battery. I will avoid a // system whenever possible.
... And the unavoidable poor quality 6V batts that led to paralleling 12V has already been established.
larry
   / Dodge Cummins Engine Concern #189
Well it is "a sad day in Mudville" for those that are old enough to understand the phrase.
The owner decided to sell it to a family friend of her father's (it was his truck, rip) and not to her friend, my wife. As a result I will not get the truck. :( Not happy, disappointed, all that, but, oh well.
Since the owner had been thinking about whether or not she would sell it for months I had put off looking elsewhere as I thought this was a deal worth waiting for.
Now I can look elsewhere without thinking that I missed a deal. I know I missed it, there is no thinking that I might.
Furu,
Here's my old '05 3500 SRW with 15K miles on it - it's still for sale - just by a different owner now:
2005 Dodge RAM 3500 SLT, Indianapolis, IN, 10690979, @ carmax.com
   / Dodge Cummins Engine Concern #190
"..You put sugar on grits,not salt...."
YOU might. I don't.
No milk, either.
A little salt pepper and tobacco sauce for the red color.
Use the grits to soak up the egg yoke.
A little red eye gravy on the cats head biscuits and thick sliced bacon .
North of the Missouri line the folks don't enjoy good food.
Now back to Dodge trucks rusting. I found the hay forks driven into the tail gate causes considerable comments.
ken
Caterpillar 906M (A53317)
Caterpillar 906M...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A55852)
2015 Freightliner...
40' CONTAINER (A52706)
2012 JCB 8030 ZTS Mini Excavator (A55851)
2012 JCB 8030 ZTS...
