Does anybody have remotes on their BX?
   / Does anybody have remotes on their BX? #21
I used the outlets for the backhoe to plumb the hydraulics for my valve. It is mounted on the ROPS. Not the best picture, but will give you some idea.
http://www.tractorbynet.com/forums/...-bx24-rear-remotes-hydraulic-top-100_0810.jpg .
Renob, thanks for the photo on your rear remotes; congratulations on a very professional looking job. I am interested in installing remotes on my BX24 as well. Would it be possible for you to post details showing to which ports on the hydraulic vave the 3 hydraulic lines for the backhoe are connected please?
   / Does anybody have remotes on their BX? #22
Here are pictures of the setup my dealer installed at delivery time on my BX24. Uses the backhoe connections that are normally connected in bypass mode when the backhoe is off.
Mpowrd, a big thanks to you also for the great photos. I am somewhat envious of the wonderful job that your dealer accomplished with your beautiful rear remotes. I am trying to figure out the routing of the 3 hydraulic lines on the rear of my BX24 to the proper ports on the new remote valves. Would it be possible for you to post details showing to which ports on the remotes the 3 lines on the back of your BX24 connect to please?
   / Does anybody have remotes on their BX? #23
lp,
I sent you a PM. Hope it helps!
   / Does anybody have remotes on their BX? #24
Renob
Doesn't the valve block get in the way when you have the hoe on?
tom
   / Does anybody have remotes on their BX? #26
Renob
tom
The block clamps to the ROPS. I only use it in the winter to angle a rear blade and occasional use with a box blade with top link. It hangs in the barn most of the time.
   / Does anybody have remotes on their BX? #27
Anyone want to share the set up?? I am looking for remotes but am stumped ?? Where did you get the hardware?? My dealer says it isnt made.
   / Does anybody have remotes on their BX? #29
I just bought the kit from my local dealer. They had to order it from kubota. The model is bx7326. The cost with freight and tax was $376. It is very easy to put on.
   / Does anybody have remotes on their BX? #30
crvoss what model BX. I have an open slot in the right fender but according to my dealer no kit is made for the BX24.
2020 John Deere 35G Mini Excavator (A49461)
2020 John Deere...
2009 MACK CXU613 DAYCAB (A50854)
2009 MACK CXU613...
2020 KUBOTA RTV...
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
NEVER USED FECON 74in Deck Mulcher FDM74 (A51039)
NEVER USED FECON...
2014 VOLVO VHD (A50854)
2014 VOLVO VHD...
