Does anybody have these on their 3pt arms?
   / Does anybody have these on their 3pt arms? #1
dubba
Merrimack county, NH
JD 110 TLB
They allow vertical movement in the arms, made it a little easier hooking up the new rake.
The other side. I have to remove the pin to rotate them to the fixed position.
   / Does anybody have these on their 3pt arms? #3
Got them on my 4210. I think I read they are useful for like rotary mowers, to allow some up and down play. I just keep mine in the fixed location. I use a chain setup on the front of my rotary cutter so it will following the ground.
   / Does anybody have these on their 3pt arms? #4
My ford 5000 has extendable lift links as well as a slot in the lift arm link similar to that to make it easier to hook up implements.
Soundguy
   / Does anybody have these on their 3pt arms? #5
I have something similar though I noticed the newer 790's don't. I never paid much attention to it until I used my rake one day and put it in the "float" position. It allows the implement to float with the terrain much better and on the rake it means less gouging.
Now I leave it in float mode for most everything. Even my rotary cutter now rides on it's skids instead of digging in on uneven ground.
Try it, you may like it for more than just hook-up /forums/images/graemlins/smile.gif
   / Does anybody have these on their 3pt arms? #6
They allow 'twist' of the attachment relative to the tractor. In thier rigid or fixed position, the attachment like a rotary cutter cannot roll or twist, which takes a lot of stress and strain off the attachment.
If one side of the rotary cutter goes over a small hill or ground mound, it will try to lift that side of the tractor if the links are not floating a bit. Easier on the equipment if floating, and more flexible to hookup attachments if still doing that without the iMatch. /forums/images/graemlins/wink.gif
</font><font color="blue" class="small">( more flexible to hookup attachments if still doing that without the <font color="green"> iMatch </font> )</font>
No iMatch for me yet. I only have one implement. It just seems like something else to take off to put the backhoe back on /forums/images/graemlins/wink.gif
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55302)
NEW HOLLAND 706 30...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2015 Volkswagen Jetta Sedan (A53424)
2015 Volkswagen...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
