Does anyone have Air springs to keep truck from squating
   / Does anyone have Air springs to keep truck from squating #41
Does using a weight-distributing hitch actually reduce how much the rear end of the truck squats?
Yes, it puts some of the weight on the front axle which reduces the weight on the rear axle.
Aaron Z
   / Does anyone have Air springs to keep truck from squating #42
If you crank up the bars, you can actually jack the truck off the ground. When using a WDH, you need to make sure that you have them setup properly. You can actually unload the rear axle too much and cause all kinds of handling issues, be certain to follow the owners manual. I run one on all my heavy trailer and I drive and F350. The hitch is just not rated to haul the heavy load without it.
   / Does anyone have Air springs to keep truck from squating #43
Self expand torn.
Toro Mower (A50324)
Toro Mower (A50324)
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
MAHINDRA MAX 24 HST COMPACT UTILITY TRACTOR WITH LOADER (A52748)
MAHINDRA MAX 24...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
