Does Everyone Have a Front Axle Leak?
   / Does Everyone Have a Front Axle Leak? #61
Almost all oils have seal swell additive. Apparently, this additive gets used up or changed in service such that the lip seals shrink a bit. New oil has new seal swell additive that "livens" up the seal again.
Ralph
Yes, but that's a stop gap measure. Why do we need to swell the seals, what's wrong with this picture?
Deere has specific fluid maintenance intervals,what happened to them?
Again, seals fail because bearings go bad or because internal pressures push out the lubricant. If you look at the tranny you'll see a vent on top, maybe the front box needs a vent?
Rob
   / Does Everyone Have a Front Axle Leak? #62
See page 4....
   / Does Everyone Have a Front Axle Leak? #63
Don't have the manual ,does it have a vent?
   / Does Everyone Have a Front Axle Leak? #64
See page 4 of this thread....
   / Does Everyone Have a Front Axle Leak? #65
Does this stop the leak?
   / Does Everyone Have a Front Axle Leak? #66
I'm thinking it prevents the leak (outside of bearing failure related leaks).
   / Does Everyone Have a Front Axle Leak? #67
OK, that's getting somewhere because it means the leak is due to pressure from expansion.
   / Does Everyone Have a Front Axle Leak? #68
Has anyone here replaced their own seals using a SKF (CR=Chicago Rawhide) brand unit? Is the oem part a nitrile seal or viton? viton being more resistant to chemicals
   / Does Everyone Have a Front Axle Leak? #69
Has anyone contacted Deere? After all these problems there must be a solution. Is it just to make sure your levels are up and how long does it take before they drop to the point the porblem has to be addressed?
Rob
   / Does Everyone Have a Front Axle Leak? #70
Rob-D
Ask and you shall receive.
JD2520 Two years ago, a day or two prior to expiry of warranty, left front seal, heavy seepage (small puddle on garage floor).
Four months later, same thing, same wheel.
Been OK since.
   / Does Everyone Have a Front Axle Leak? #71
i was going to look into it to see if i can match it, but haven't gotten around to it. the knuckle seal is about 4" in diameter, and about $20 from JD. not sure how cheap you can find seals this big...seems to me when i buy 1.5" seals, thay are about $6-$8, so $20 for a 4" doesn't seem too far out of line. but one of these days, i still want to check.
   / Does Everyone Have a Front Axle Leak? #72
Rob-D
Been OK since.
So did it lose fluid at a greater rate than the normal service interval for checking it? Maybe Deere figures you'll lose fluids under certain conditions but isn't concerned because you should be checking levels before it reaches a dangerous point.
2010 CATERPILLAR 924H WHEEL LOADER (A60429)
2010 CATERPILLAR...
2020 JOHN DEERE GATOR SUV590M S4 UTV (A60430)
2020 JOHN DEERE...
2016 KOMATSU D65EX-18 CRAWLER DOZER (A60429)
2016 KOMATSU...
2018 Dodge 5500 Bucket Truck 4WD (A61306)
2018 Dodge 5500...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2016 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2016 CHEVROLET...
