Does MFWD replace HP ?
   / Does MFWD replace HP ? #11
Does MFWD replace HP? I would say the answer is usually no. People are confusing weight with MFWD and HP.
Maybe the question should be "Does MFWD replace weight?" Then the answer is probably yes in most cases. I have a 130 hp, rear duals, IH 1086 and 2008 Case IH 125 (125hp) MFWD. The 1086 wieghs about 1000 lbs more than the 125. Pulling the same 21' disc, the 125 does a better job. The MFWD results in less slippage because the weight is better balanced over the tires. The newer 125 also has the advantage of auto locking the front and rear differentials and this makes pulling heavy loads very noticeable.
   / Does MFWD replace HP ? #12
Which is, I guess, the reason a lot of commercial farmers use rubber belted track tractors
8R/8RT Series Tractors
My neighbor uses his old steel track D7 Cat to rip and disc his alfalfa fields and says it produces less compaction than his MF 294S 4WD tractor even though the D7 weighs about 4 times more than the 294.
This has been the accepted rational that tracked machines cause less compaction. A recent study by the Univ of SD discovered a tracked tractor may have as much compaction or more compared to a MFWD tractor with rear duals. What they discovered is ground is not perfectly flat. Any rise or dip resulted in high compaction areas because the wheels and rollers exerted a lot of pressure over a relatively small area. Newer ag tractor radial tires have a larger footprint than prior belted tires, run at a lower psi, are larger in diameter and have give in the sidewalls. This helps to reduce compaction. I suspect the D7 is causing a lot more compaction than he thinks.
Tracked tractors ride harsh on the road because the is no give between the belted track and solid steel rim. This effect is not noticed in the field and most seem to ride smoother over dips, bumps ect. Tracks also leave berms of dirt on the ends when turning and not as useful in row crops because they flatten more crop when turning.
   / Does MFWD replace HP ? #13
In a nut shell if you need pto power HP is king. If you need pulling power MFWD is king.
Here is my situation. I have a Ford 861 Powermaster 48HP 2 Wheel Drive.
My second tractor is a Jinma 284 28HP 4 Wheel Drive. The Jinma will out pull the Ford any day of the week. It does not matter if I am pulling out a stuck truck, logs, 2 bottom plow, ect it just plain out works it. Nothing wrong with the Ford and its great for PTO jobs like Bush Hogging but when it comes to 95% of the task I do the Jinma out shines it.
Chris
Chris
Apply some physics please. A 28 light duty machine will not out pull a 48 hp heavier machine given equal traction.
   / Does MFWD replace HP ? #14
I have always been told and read that in identical tractors having FWA adds 30 percent to the amount of pulling from the drawbar.
It does make a big difference but only when comparing apples to apples. Obviously, a big heavy 2wd will out perform a smaller lighter 4wd.
   / Does MFWD replace HP ? #15
Chris
Sure it will. They both weigh about the same, Ford 2991# and the Jinma 3003#, and the gear selection is much better on the Jinma. The Ford only has 1 wheel pulling while the Jinma has MFWD and a locking rear diff. Does not take a rocket scientist to see when you hook a chain to a stump, log, or shrub and try to pull it with the Ford and its a no go then go get the Jinma and it yanks it right out there is a advantage.
Chris
   / Does MFWD replace HP ? #16
Chris
I said given equal traction :D
   / Does MFWD replace HP ? #17
Firestone tire company and Nebraska college or university did a study back in the 70's on HP transfer efficiency. And that the conclusion was you could effectively utilize 100 HP in a 2WD tractor on good footing. (NOTE: I do NOT remember what percentage of wheel slip they considered acceptable or normal) Adding MFWA increased this by 25%. Newer radial tires may have raised these numbers but like other have stated....
If using for PTO HP will win, if using for pulling implements traction will win. Boils down to conditions present. Since spinning / slipping wheels consume HP MFWA will reduce the slippage.
Roy
   / Does MFWD replace HP ? #18
MFWD or not ... its still the same HP at the PTO or draw bar.
   / Does MFWD replace HP ? #19
This is true, the variable is how efficiently is this power utilized.
Review this post by radman, it explains this very well.
Roy
Pallet of Nail Guns & Nails (A53117)
Pallet of Nail...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2025 Star EV Capella 2+2 Electric Cart (A51694)
2025 Star EV...
2015 CHEVROLET SILVERADO 2500HD (A53843)
2015 CHEVROLET...
2025 K2030 UNUSED Metal Garage (A53117)
2025 K2030 UNUSED...
