Does size really matter?
   / Does size really matter? #1
Zoombah
Central Texas
Ha!
Getting a loader added to my tractor. Hydraulics will be connected to the rear remotes via flex-lines. I don't claim to know what I'm talking about so please excuse what may be a dumb question.
I have read about 3/8 and 1/2 inch lines. What size flex-lines do I need to run a Bush Hog 446 loader on a tractor with a 12.5 gpm flow rate?
Ha!
   / Does size really matter? #3
The rear remotes are not in a hurry to get anywhere fast, relatively small overall displacement, very short lines so size is less important then one would be led to believe. 3/8" is OK for TnT cylinders if that is what we are talking about. Personally, I find the 3/8" lines more then sufficient for our compact tractors. You will hear it mentioned that going one size up on the quick couplers is the way to go. I havent found that there is that much difference. I had a Kubota L48 with 1/2" lines and couplers to the TnT and now I have a Kubota L3830 with 3/8" lines and couplers to the TnT. Frankly, I see no difference in the speed of the TnT cylinders. I like the smaller lines.
   / Does size really matter? #4
   / Does size really matter? #5
</font><font color="blue" class="small">( 3/8" is OK for TnT cylinders if that is what we are talking about. )</font>
I think he's not talking about TnT at all, but adding a front end loader and using the rear remotes to power the loader.
I don't know a lot about hydraulics, but this isn't the best way to go, is it?
John
   / Does size really matter? #6
John
Yes....I'm adding a front end loader . Only place to connect to hydraulics is via the rear remotes. Question is ... does it matter if line size is 3/8 inch versus 1/2 inch?
Thanks
Thanks
   / Does size really matter? #9
A simple rule of thumb is the bigger the hose diameter the more flow will be required. I have a chart at home that gives optimal flow for each hose diameter and I'll post it tonite. Based on the gpm you gave, assuming that's the entire implement flow, I would use nothing less than 3/8" hose. If I recall correctly, if the flow exceeds 17 gpm then 1/2" is the correct size.
BTW, why don't you fill out your profile so we can see what kind of equiupment you are talking about? It may just help us give you a better answer. Since we don't know what kind of tractor your are talking about you surely can't expect any kind of accurate answer.
   / Does size really matter? #10
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A51039)
2018 Dodge Ram...
2017 Mahindra 85P 4WD Tractor (A50860)
2017 Mahindra 85P...
2001 Lexus LS 430 Sedan (A48082)
2001 Lexus LS 430...
2016 Dodge Charger Sedan (A48082)
2016 Dodge Charger...
2025 KG43 UNUSED Chain and Ratchet Binder Set (A50860)
2025 KG43 UNUSED...
2008 JACK COUNTY  130BBL VACUUM TRAILER (A50854)
2008 JACK COUNTY...
