Does size really matter?
   / Does size really matter? #1
Zoombah
Central Texas
Ha!
Getting a loader added to my tractor. Hydraulics will be connected to the rear remotes via flex-lines. I don't claim to know what I'm talking about so please excuse what may be a dumb question.
I have read about 3/8 and 1/2 inch lines. What size flex-lines do I need to run a Bush Hog 446 loader on a tractor with a 12.5 gpm flow rate?
Ha!
   / Does size really matter? #3
The rear remotes are not in a hurry to get anywhere fast, relatively small overall displacement, very short lines so size is less important then one would be led to believe. 3/8" is OK for TnT cylinders if that is what we are talking about. Personally, I find the 3/8" lines more then sufficient for our compact tractors. You will hear it mentioned that going one size up on the quick couplers is the way to go. I havent found that there is that much difference. I had a Kubota L48 with 1/2" lines and couplers to the TnT and now I have a Kubota L3830 with 3/8" lines and couplers to the TnT. Frankly, I see no difference in the speed of the TnT cylinders. I like the smaller lines.
   / Does size really matter? #4
   / Does size really matter? #5
</font><font color="blue" class="small">( 3/8" is OK for TnT cylinders if that is what we are talking about. )</font>
I think he's not talking about TnT at all, but adding a front end loader and using the rear remotes to power the loader.
I don't know a lot about hydraulics, but this isn't the best way to go, is it?
John
   / Does size really matter? #6
John
Yes....I'm adding a front end loader . Only place to connect to hydraulics is via the rear remotes. Question is ... does it matter if line size is 3/8 inch versus 1/2 inch?
Thanks
Thanks
   / Does size really matter? #9
A simple rule of thumb is the bigger the hose diameter the more flow will be required. I have a chart at home that gives optimal flow for each hose diameter and I'll post it tonite. Based on the gpm you gave, assuming that's the entire implement flow, I would use nothing less than 3/8" hose. If I recall correctly, if the flow exceeds 17 gpm then 1/2" is the correct size.
BTW, why don't you fill out your profile so we can see what kind of equiupment you are talking about? It may just help us give you a better answer. Since we don't know what kind of tractor your are talking about you surely can't expect any kind of accurate answer.
   / Does size really matter? #10
2014 Dodge Ram 1500 Pickup Truck (A50860)
2014 Dodge Ram...
2007 Ford F-150 Ext. Cab Pickup Truck (A48081)
2007 Ford F-150...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
Bottle Storage Rack (A50860)
Bottle Storage...
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
