I believe having the FEL on can both hurt and help stability. The FEL is attached at the belly of the tractor just behind the front wheel, so this is where all the forces to the tractor are applied. Please note I mentioned the forces and not the weight. 1]Then you have 2 towers that act as lever arms, and since the FEL is sticking out in front, the force on the tower arms is such that it is trying to rotate them forward. When the tractor is stationary, this forward rotational force is the same whether the FEL is at 7 or 11 and at 8 or 10 o'clock. This is because the horizontal distance these arms reach forward is the same at both points. Therefore, this forward rotational force is greatest at 9 o'clock as it is also the greatest distance forward. However, if the tractor is sitting sideways on a hill, it is like someone attaching a tow strap to the FEL towers on the down hill side. If the bucket is as low as possible, it would be like someone pulling down on the tow strap right next to the tractor. No major sideways force here since the force pulling down on the tower is in a pretty steep angle. However, as the FEL is raised so will be the point from which this tow strap is pulled from. Thus, making it easier to roll the tractor over. Then you have momentum, which only exaggerates the forces applied when changing direction like braking, speeding up and turning. Therefore, mowing in a straight line without changing speed or direction, makes all the forces like you were sitting still. I am sure we all understand these concepts, but thought I would mention them here to help explain my following comment. If the center of gravity of the FEL is kept below the center of gravity of the tractor, it 2]can help stability. If the FEL is higher than the tractor's center of gravity, of course it will hurt it. My FEL adds about 1100 lbs to the weight of my tractor which helps with a lot of traction on those front tires. This really helps my sticking power on hills.
