Dolly for mower
/ Dolly for mower #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I have a 5' rough cut mower. I have tried making a dolly to go under the front edge so that I can move it around in the barn. My problem has been making something that can handle the weight and still be low enough to be able to get the mower on and off the tractor. Does anyone have some pictures of things like this they have made?
/ Dolly for mower #2
I simply use two furniture dollies from TSC with a furring strip strapping them together, works like a champ, cost is $39.98 and time required is about 4 minutes to rig it up. I should add that I put the dollies under the sides so all of the cutter is supported by the dollies, this is the way I do all of my stuff, spreader, tiller, bh, fel, etc.
/ Dolly for mower #3
Dollies for me too. I have 6 or so from Harbor Freight. $12 or $15 each I think, when on sale. I don't tie them together though, so I can use 4 under the mower, or 3 under the snow plow, etc. It is remarkable how easy things roll on those things! It's also nice if you keep them separate since you can stack them when not in use and take up little room.
/ Dolly for mower #4
I made a roller lift to haul a snowmobile around and it works for a mower, too. I believe there is a commercial version of this for snowmobiles.
/ Dolly for mower #5
My rough cutter is only 40" wide and about 380 lb. I have it on a dolly, no pics already posted. Most of my implements are on custom home made dollies. The mmm is on 1/2" plywood with 2" swivel casters (I do have pics in the Kubota O/O forum of this). I found some 1000lb. steel 2" casters recently at a local industrial supply house. Home Depot has some that are similar.
/ Dolly for mower #6
I've heavy duty metal castor wheels attached to 1bys at the end of a 1by that goes the width of the unit. Don't have pictures of this current setup but I'll post pictures of the 3 wheel castors I used that weren't quite up to snuff (wheels broke after a bit of usage).
The single wheels at each end present a slight problem of how to hold them upright while lowering the unit onto the 1by. I just sit a 2by4 on edge underneath one side. There's just enough height to slide the 2by4 back out once the unit sits on the 1by.
Note the dolly shot is upside down.
Ralph
/ Dolly for mower
Well harbor Freight just happens to have their dollies on sale. I picked up some of the mini dollies for $10 each. I put them under all my stuff and they work great. That was cheaper than buying casters.
/ Dolly for mower #8
Ralph
Geez...Ralph...you still can read the decals on the side of your rotary mower...:D
/ Dolly for mower #9
Any ideas on the weight limit for those dollies from HF? My cutter weighs 1024 lbs and I'm wondering if two on each side would be enough. Thanks.
/ Dolly for mower #10
2 on each side, 4 total, will work fine. They are rated for 1000 lbs, but I've tested that and they will barely roll with that much weight. With 4 dollies you will be able to roll it easily.
/ Dolly for mower #11
I made dollies for my husband, for his attachments. I just used pallets, swivel wheles on the corners and most importantly one in the center of the pallet.
/ Dolly for mower #12
I had a bit of a height problem after i put my 47" snowthrower onto a dolly which I'd made out of pressure treated 2x8's and 4 rubber wheeled casters rated for 400 lb. each. My JD 2320 was about 1" too low to engage the quick attach to the bracket mounted on the loader. Solution? Put 2 short pieces of 2x8 board onto the floor in front of the wheels which allowed me to line up the attachment and then drive the tractor up onto the board to gain the height differential.
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
Sellick S80 (A60462)
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
429858 (A61165)
429858 (A61165)
