"Don't change Hydro oil at 50 hrs" says Dealer
   / "Don't change Hydro oil at 50 hrs" says Dealer #31
Re: \"Don\'t change Hydro oil at 50 hrs\" says Dealer
I'm with you on that one. Same instructions for most of my equipment. I mean once you're there and the oil is drained, why not change the filter? It's not like you're going to break the bank.
   / "Don't change Hydro oil at 50 hrs" says Dealer #32
Re: "Don\'t change Hydro oil at 50 hrs" says Dealer
I agree, you went to the trouble of changing fluid, you also change the filter...
Kinda like a kid taking a nice clean bath, drys off, then puts dirty underwear back on... /w3tcompact/icons/shocked.gif
   / "Don't change Hydro oil at 50 hrs" says Dealer #33
GlueGuy,
<font color=blue>I looked at the manual, and the 50 hour service says to change the hydraulic fluid, but not the filters or even clean the screens.</font color=blue>
My "operators manual' shows engine and transmission filter change plus engine and transmission oil change. It further states these jobs must be done at 50 hr.
This information is on the "Service Interval" chart.(B7400/B7500)
What are you reading from?
Al
   / "Don't change Hydro oil at 50 hrs" says Dealer #34
I just took a look around the Chevron website. Both the web page and the downloadable salesfax (*.pdf) for the Synthetic All-Weather THF include UDT and Super UDT, plus a bunch more:
John Deere — J20C, J20D
AGCO — improved power fluid 821XL
Ford New Holland — ESN-M2C134-D, FNHA-2-C-201, FNHA-2-C-200
Massey Ferguson — M1135, M1141, M1127, M1129A
White Farm Equipment — Q-1826
Case — JIC-143, JIC-145, MS 1206, MS 1207
Oliver — Type 55
Minneapolis-Moline Fluids
Caterpillar TO-2
Renk — Bus Automatic Transmission Fluid
Allison C4
Kubota Super UDT, UDT
International Harvester B6
   / "Don't change Hydro oil at 50 hrs" says Dealer #35
Al,
Sounds like the same manual. Mine's the "Operator's Manual" for the B7400/B7500. The code number on the back of the manual is: 6C120-6311-2.
The chart I am reading is on page 48 (first page of the maintenance section). Items marked for change/replace at 50 hours are (1)Engine oil, (2)Engine oil filter, (3)Trans oil filter, (4)Trans fluid.
Whoops. I see what I did. Item (5) Trans strainer is not marked. I guess I miss-read it.
The GlueGuy
   / "Don't change Hydro oil at 50 hrs" says Dealer #36
It may meet the lubrication requirements, of both UDT and Super UDT as I think UDT meets the LUBRICATION requirements of Super UDT. I don't think I'm damaging my L35 by using UDT, but it does operate slower with the UDT.
   / "Don't change Hydro oil at 50 hrs" says Dealer #37
Sounds like you don't see really low temperatures where you are - I was interested in the differences at around 32 F and below (gets to -10 F occasionally here during a Winter). I'll have to go back a find that thread that you had started with all the UDT / Super UDT discussions.
The writers of my Owners Manual liked to keep their options open - the lubricant spec. table lists UDT or Super UDT, but the section on fluid replacement only lists Super UDT. Maybe a 50/50 mix? /w3tcompact/icons/smile.gif
Rob
   / "Don't change Hydro oil at 50 hrs" says Dealer #38
If I was contemplating much of any below 40 use, (tractor is in garage before use) I wouldn't think twice about the Super.
Speaking of oil recom's, my manual says for the front differential, EITHER SUPER UDT or 80/90W? What... 90 wt is OK but UDT isn't? I've never seen a recommendation so goofy. What is Super, about 10W? How about saying, use anything you can pour through a funnel? /w3tcompact/icons/smile.gif
del
   / "Don't change Hydro oil at 50 hrs" says Dealer #39
<font color=blue>use anything you can pour through a funnel</font color=blue>
Only if it feels slick, del./w3tcompact/icons/laugh.gif
Bird
   / "Don't change Hydro oil at 50 hrs" says Dealer #40
Bird, YOU'RE RIGHT!
I guess pouring rice or sand wouldn't work too well.
2009 Volkswagen Jetta Sedan (A51694)
2009 Volkswagen...
50ft Fuel Line (A51573)
50ft Fuel Line...
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
Unused Delta Crash...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
