Downsized engines=shorter life?
   / Downsized engines=shorter life?
How long they're going to last would depend on how beefy the bottom end is, like diameter and width of bearings. More boost equals higher bearing loads.
And you just hit THAT ONE right on the head....today's automakers are constantly trying to build lighter and cheaper vehicles...my wife formerly had a 2011 Malibu with the regular 2.4 Ecotec...it was so slow it could barely get out of it's own way...NOBODY can convince me the 2016 version with the 1.5 turbo Ecotec is going to be built any stronger engine wise than her older model was.
   / Downsized engines=shorter life? #12
I don't understand. Are you trying to say that you don't get something for nothing? You seem to think that a little teeny motor motor running hard as he!! might not last as long as larger motor just chugging along. WHY that's just crazy talk.
If it has ECO in it it must be better.
   / Downsized engines=shorter life? #13
Seems like the engines in new vehicles constantly get smaller to increase mpg and I wonder how downsizing will affect service life. I began pulling travel and boat trailers back in the early 80's and the understanding then was that a small engine straining to pull a load would consume about the same amount of fuel as a larger engine that could comfortably handle the same load, and the bigger engine would have a longer service life. My last Ford F-150 pickup had the 5.0 V8 and I used it to pull a 7000 pound travel trailer...it did the job okay but had to work hard at times. Today's F-150 is available with an engine as small as the 2.7 Ecoboost and they are rated to tow more than the 7000 pounds my truck used an engine almost 2X the size to pull. I would have reservations about using such a small engine for 7000 pound towing because I would wonder about the service life. Thank you for any input on the subject.
I have the 3.5 F150 EcoBoost. I can tell you it will out pull any large displacement gas engine I have had. The biggest being a 1997 Dually GMC 454. At 70,000 miles it's been absolutely trouble free as are most new things.
Chris
Chris
I have a 3/4 ton GMC with the 8.1 and 4.10 gears....it has been quite trouble free and is a beast when towing although it eats up gas.
   / Downsized engines=shorter life? #15
There is quite an upcharge to move from the 5.0 V8 to the 3.5 Ecoboost. It's not paying for unreliable technology. If the technology didn't pay off, every thing would be based on cubic inches. Ever watch a 1200 cc Harley take on a 600 cc sport bike?
   / Downsized engines=shorter life? #16
Chris
You're saying a 213.583 cubic inch engine outpulls any 454 you ever had?
1997 454 = 410 ft pounds of torque and 290HP
Gotta be wrong.... so I looked it up... Well heck, the 3.5 gets well over 300hp and 420 on torque. Who'da thunk it? :confused2:
Its the electronics on these new engines that really bothers me. Time. Not mileage. Electronics don't last as long as the mechanicals. Only time will tell.
   / Downsized engines=shorter life? #17
Another indication of how tough the ecoboost is built - as I understand it, the weight of the 3.5 EB and the 5.0 are almost identical. Some of the weight is the turbo but some is probably a really strong block and crank.
   / Downsized engines=shorter life? #18
I've been wondering the same thing... reliability/longevity over the long haul like the 25 years or so I keep my vehicles.
Have to be some tradeoffs using thinner and lighter materials for drivetrain components.
I've seen cast iron engines overheat and go on for years... also seen aluminum engines overheat once and that was it.
Guess time will tell...
   / Downsized engines=shorter life? #19
Just my opinion here, not really based on facts but experience, but it seems like an engine failing is not usually the reason a vehicle goes to the scrap yard. I'm talking an actual mechanical failure where the engine would have to be rebuilt or replaced. Its usually the electronics, transmission, body falling apart or a number of smaller repairs piling up and not worth fixing.
I see no reason the low displacement turbocharged engines should be any different.
We have 3 of the 2014 5.0 trucks at work. 4x4 extended cab short bed. I'm impressed with the trucks, good power, very comfortable, but the gas mileage sucks. They are work trucks so the one I drive carries a lot of weight, they get driven in town a lot, idle some, driven around farm fields at low speed, but its not uncommon to see the fuel mileage at less than 10 mpg. Even out on the highway I never see them get up near 20 mpg. I've never driven the Eco-boost but I'm betting they would get better MPG.
   / Downsized engines=shorter life? #20
The number one reason for most otherwise sound vehicles heading for scrap is emission test failure.
In California just about everything 1976 and newer is tested.
Rust is NEVER an issue.
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A55314)
2023 Top Air ATV...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2011 Ford F-150...
Plasmarc PM150 Plasma Cutter (A55851)
Plasmarc PM150...
Toro Mower (A50324)
Toro Mower (A50324)
