DR Power Grader Wiring
   / DR Power Grader Wiring #1
adventure bob
Platinum Member
Here
JD 345/ Kubota Side by/ kubota ??
My DR grader took a hit to the connector and relay box. I have the new relay box, but need to know what wire go to what. They are different colors on either side of the connector.
Could someone with a DR with the remote take a look and post wire to wire colors over the connector?
Thanks
   / DR Power Grader Wiring #2
Here you go.
Thanks, but that WD is for the hardwired switch version. I need the one for the remote control version. It operates from two independent relays, not a DP/DT switch, wiring is different.
I tried looking for one with the remote and non of the pubs by DR seem to have that WD. Searched my fingers off trying to find one, no joy.
BC
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2023 Kubota L6060HST Compact Utility Tractor (A56436)
2023 Kubota...
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
TANK MANIFOLD (A58214)
