DR Power Grader Wiring
   / DR Power Grader Wiring #1
adventure bob
Platinum Member
Here
JD 345/ Kubota Side by/ kubota ??
My DR grader took a hit to the connector and relay box. I have the new relay box, but need to know what wire go to what. They are different colors on either side of the connector.
Could someone with a DR with the remote take a look and post wire to wire colors over the connector?
Thanks
   / DR Power Grader Wiring #2
Here you go.
Thanks, but that WD is for the hardwired switch version. I need the one for the remote control version. It operates from two independent relays, not a DP/DT switch, wiring is different.
I tried looking for one with the remote and non of the pubs by DR seem to have that WD. Searched my fingers off trying to find one, no joy.
BC
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
2020 Utility Trailer (A60460)
2020 Utility...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
