Draft Control on Kubota GrandL series
   / Draft Control on Kubota GrandL series #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
I was looking at the GrandL series catalog today. I noticed that all of the GrandL series, from L3130 to the top of the line L5030 all have draft control as an option. Now, I am curious as to why draft control is an option on all the GrandL series? I thought draft control was used for ground engaging implements like a 2 bottom plow. Can a 32 HP tractor pull a ground engaging implement like a bottom plow? I thought bottom plows took a lot of power. Is 32 HP enough power???
Bob
   / Draft Control on Kubota GrandL series #3
Yes, 32HP is enough, Doc Bob, but a few other factors have to be right as well. The weight has to be there and so do R1 tires and good gearing.
As I recall the old JD40 with a 100 cu. in. 2 cylinder gas engine of around 25HP was rated at 2-14s. It didn't pull 'em very fast though. The small Fords would handle a 2-bottom plow as well. My 3 cylinder Ford 2000 does a fair job with 2 bottoms. It's biggest problem is lack of weight on the rear tires and a low gear that's a bit fast....its 35HP is plenty, however. I think with good gearing and filled rears, an 8N or 2N would do OK as well. Keep in mind, these are all 2WD tractors.
A Grand L, regardless of HP, has the weight (especially with the rear tires filled) and the gearing. Should be able to handle 2 bottoms with ease. I'd expect the L4330s and above to be capable of 3 bottoms. 15HP per bottom is a conservative rule of thumb...if everthing else is right. A B3030 wouldn't be a good choice, however.
Bob
</font><font color="blue" class="small">( Well, it depends... try this site for details. )</font>
Nice chart. I am struggling with understanding it and applying it. Any help???
Bob
I tried a sample calculation.
Moldboard
4.5 mph x 2.1 x 800 / 375=20.16 HP for PTO.
So, one bottom plow would take 20 PTO HP?
Bob
PS Why is sandy soil 2.1 and form soil 1.5? I woulld have thought it would have been the other way around?
   / Draft Control on Kubota GrandL series #6
I have a Kubota L3430 and a King Kutter Two Bottom 14" Plow. I can pull it no problem in low range, four wheel drive at about 3 - 4 mph.
ksmmoto
</font><font color="blue" class="small">( I have a Kubota L3430 and a King Kutter Two Bottom 14" Plow. I can pull it no problem in low range, four wheel drive at about 3 - 4 mph.
ksmmoto )</font>
Nice to hear from someone who is actaully using it! Do you have draft control?
Bob
   / Draft Control on Kubota GrandL series #8
No, I don't have draft control. I haven't plowed a very large area yet, so I'm not sure if it is really needed.
In fact, I believe having HST will help with the plowing as I can letup slightly if the plow hits a hard spot and the tractor will keep pulling strong.
I know most people will say that gear is best for field work and they may well be right for large fields. But I may only do three acres at the most at one time.
ksmmoto
ksmmoto )</font>
What kind of soil? Virgin? Sand? Clay?
Bob
   / Draft Control on Kubota GrandL series #10
I have been pulling a 2 bt plow with a 45 hp tractor and it has to work but I am plowing ground that hasn't been turned over in 25 years and the sod is thick and heavy. I think soil conditions mean a lot and also how you have the plow set up. My tractor has draft control as a standard feature and that's one of the reasons I bought it.
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
JLG 1255 Telehandler (A52128)
JLG 1255...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
Swamp Buggy (A49346)
2021 KUBOTA SVL 97-2 SKID STEER (A51242)
2021 KUBOTA SVL...
FORD COBRA REPLICA RACING CAR (A51222)
FORD COBRA REPLICA...
