Drain plug 3/8 +/-
   / Drain plug 3/8 +/- #1
marhar
Denton NC
Farm Trac 60
I have a lawn tractor that has a 3/8" square drain plug (it is a little bigger than 3/8 I cannot put a 3/8 ext bar on it). It is a very tight spot to get a wrench on it. Now I take a 1/2" ext bar and put a wrench on the drive end to turn the plug. The 1/2 is a little "sloppy". Any ideas?
   / Drain plug 3/8 +/- #2
Is the square part male or female? If male you might be able to find a 12 point socket to fit. There are 8 point sockets made for those.
It is male.
   / Drain plug 3/8 +/- #5
You didn't say what this is. 3/8" pipe size or head size? Possible that it is a 10 MM or 7/16" ? Evac it through the dipstick or drain via the filter are other possibilities.
   / Drain plug 3/8 +/- #6
i have seldom seen any square head that was a exact size. especially on a pipe plug which most drain plugs are.
if you have room to get a socket on it try metric as well. there should be some size that will grip it. same with wrenches. on both try 6 or 12 point.
also have used a large vice-grip and small pipe wrench.
   / Drain plug 3/8 +/- #8
most pipe plugs the square is also tapered a little which makes a standard open end wrench fit even worse. I have a 3/8" 8 point socket that is meant for square heads and works most of the time. Seems like some of the newer plugs are more of an oddball size that older ones.
   / Drain plug 3/8 +/- #10
Since it sounds like it is doable but not easy, the next time you get it out replace it with a hex plug.
Swict 72in Bucket Skid Steer Attachment (A44571)
Swict 72in Bucket...
More info coming soon! (A44572)
More info coming...
2018 FREIGHTLINER M2 26FT BOX TRUCK (A43004)
2018 FREIGHTLINER...
2019 Ford F-350 4x4 Dually Truck, VIN # 1FT8W3DTXKEG40391 (A44391)
2019 Ford F-350...
2012 VOLVO VNL SLEEPER (A43003)
2012 VOLVO VNL...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A44572)
Year: 2017 Make...
