Draining new style fuel filter
   / Draining new style fuel filter #1
ericm979
Super Member
Santa Cruz Mountains CA, Southern OR
Branson 3725H Deere 5105
Hi guys, m 3725 has the newer clear plastic bowl type fuel filter with the priming pump. I see a bit of gunk in the bottom of the bowl and I'd like to drain it. There's a drain knob on the bottom of the bowl with a hose nipple. When I put a hose on it and loosen the knob air is sucked in around the threads but nothing comes out the hose. Is fuel supposed to come out of the hose nipple?
I can't find anything about this in the manual.
   / Draining new style fuel filter #2
Eric, I'm going off my memory which isn't very good.
I recall a filter element in the clear plastic bowl which I unscrewed (or unclipped) and emptied out. Besides the filter element that needed to be replaced, there was some water that had trapped in there which I emptied out.
I might not be answering your question but hopefully this helps.
edit: I don't recall a priming pump, maybe my tractor doesn't have one?
   / Draining new style fuel filter #3
Eric is this the fuel filter that has the red float ring in the bottom of the bowl?
Yep it's the filter with the red plastic float to indicate water.
I know I can remove the whole bowl but I'd like to just drain the bottom of the bowl as that's less of a mess.
The prime pump is the shiny metal button about 1-1.5" diameter on the top at an angle.
Another question: when you prime it do you need to open a bleed screw?
2016 KOMATSU D65PX-18 BULL DOZER (A55745)
2016 KOMATSU...
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
2017 Ram 4500 Bucket Truck (A55302)
2017 Ram 4500...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
40' High Cube Multi-Door Container (A53316)
40' High Cube...
