Drill Bits - Need some help and advice
   / Drill Bits - Need some help and advice #51
   / Drill Bits - Need some help and advice #52
Yea , I Already Tried That !!!!:thumbsup: She won't even Ask .:( Fred H.
I'm currently bidding on one locally but bidding is already up to $1350 with 3 days to go. :(
Terry
   / Drill Bits - Need some help and advice #53
Here is a cheap and easy way to check the proper angle of a drill bit. Most of us here have two of these. :D
Ha ha... Pretty close with that shop tool... only 2 degrees off. :D Can't say I have ever measured anything with my nuts though.
   / Drill Bits - Need some help and advice #54
You're not likely to soften HSS by grinding. You can silver solder it to a boring bar (red hot) and it will still be hard when it cools. Carbon steel is a different story.
Hardening is speed dependent. If you heat a soft carbon steel above the Curie point fast cooling will make it hard. If you reheat that same steel above the Curie point and then very slowly cool it, it will be soft again. HSS will become soft when it is heated to high temperatures but the speed that it cools at in air is sufficient to make it hard but it does not become as hard again as it was in it's preheated state. You might start at 67-70rc and then end up at 58-60rc which is still hard enough to be a good cutting edge.
   / Drill Bits - Need some help and advice #55
Yeah nobody will know the units but you can usually count with them. For example the number of degrees off. Or you could count the number of people who know the angle is wrong.
   / Drill Bits - Need some help and advice #56
Adherence to the 118^ drill point is to avoid being sued by Apple (TM) for patent infringement.
They invented the 120^ angle too ... :rolleyes:
   / Drill Bits - Need some help and advice #57
Typically I measure the degrees by the size of the nuts.
   / Drill Bits - Need some help and advice #58
Quench and temper is all I know. Never heard of a tool steel that would go to 67/ 70. Stratified yes uniform no. M4 vacuum melt degassed best 62/64. Carbide yes on a different scale..
   / Drill Bits - Need some help and advice #59
The M40 series and T15 can be hardened to 70rc according to Machinery's Handbook 29th Edition.
   / Drill Bits - Need some help and advice #60
Here is what i use to get me in the ballpark. mild steel 80sfm x 4 = 320 rpm for a 1 " drill. So just divide it from their. if 1" =320rpm then 1/2" = 640rpm and 1/4" = 1280rpm and so on. For Stainless steel i cut the speed by 1/2 and aluminum i go about 25% faster This gets me in the ballpark and i dont burn up my drill bits.
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2018 Big Tex Tandem Equipment Trailer (A52384)
2018 Big Tex...
2013 Great Dane 53ft T/A Reefer Trailer (A51692)
2013 Great Dane...
