Drill Press
/ Drill Press #1
bgott
Houston, TX.
2001 TN65, 1951 8N Ford
I have been in the market for a drill press for quite a while. I don't like the looks of the chinzy "home workshop" models and don't like the price of the proffessional models. I have been working the estate sales and the auctions and all I have seen have been basically junk. I stumbled into this Buffalo Forge unit and, although I paid more than I would have liked, $275, I think I got a pretty good deal. I didn't get any before pictures but imagine this thing with a quarter to a half an inch of grease, grim and dirt and you'll know what it looked like when I found it.
/ Drill Press
This thing has the original paint on it and it isn't in that bad of shape. The spindle only has .001 total indicated runout. The only problem it has is the motor is has a little rattle while running in forward. If it gets to bothering me I'll change it out in ten years or so. /forums/images/graemlins/smile.gif
/ Drill Press
I really like the table jack. All of the new ones have a rack and pinon set up. This one looks like you could lift a house on it.
/ Drill Press
As close as I can figure this unit is at least 50 years old. the data plate is missing so I have no real way of telling. This is a No. 18, obviously, which means its an 18" drill press. That, for those of you who don't know, means you can drill a hole in the middle of an 18" piece of material. The center of the chuck is 9" from the post. I didn't know this until I was doing some research on this unit. I hope I'm not the only one! /forums/images/graemlins/blush.gif The machine is rated to drill a 1" hole but you can stretch that a little.
/ Drill Press
It still has the remains of the original sticker. I thought about repainting it but it will probably have more value with the original paint if I ever go to sell it.
/ Drill Press
Let's try that again.
/ Drill Press #9
If you still think you paid to much.. just bring it by and I'll give you $285! /forums/images/graemlins/grin.gif It's probably better then a new one!
/ Drill Press #10
The OLD machines were built to last, unlike the ones of today.
/ Drill Press #11
Yep thats the route I want to go, auctions, garage sales and such.
You can drill as big of a hole as you want as long as the shank fits and you have patients and money enuff to drill all of the pilot holes.
/ Drill Press #12
Yep. My grandfather gave me a drill press he was no longer using about 10 years ago. It's an old cast iron Rockwell Delta. I asekd when he bought it, and he couldn't remember. He just said "right after I got back from WW2". He owned a machine shop back then, and sold the machine shop in the late 50's, so the drill press I have must have been made in the early 50's or late 40's. It has 1947 on it in one place, but it's listed under the model number rather than the date. Still works great, I only worry about someone sticking thier hand in the pulleys while it's running.
/ Drill Press #13
</font><font color="blue" class="small">( although I paid more than I would have liked, $275)</font>
I would guess that thing didn't cost that much new. Funny how simple but durably built Americana stuff has held it value. I can tell you, it can be rebuilt over and over, and can outlast you and I. Good find.
/ Drill Press #15
What is a good NEW drill press brand on the market today?
/ Drill Press
It all depends on your definition of "good". Craftsman makes (or sells) drill presses that lots of people swear by. And at, also. /forums/images/graemlins/crazy.gif For woodwork and light metal work I'm sure they'll do fine. Delta has a good name and the Rigid press doesn't look bad. Grainger has a wide range of drill presses in their Dayton line but they tend to be pricey. I have noticed that Grainger's prices seem to be getting more affordable to the common man. I want to use mine to make metal swages and fixtures for the blacksmithing I mess around with and I also have been known to want to drill big holes in thick pieces of metal for various reasons. This thing also has an MT 3 quill so I can drop the arbor and chuck out of it and use it with different machine tools. There is a book about using your drill press for doing simple mill work and this unit is way cheaper than a Bridgeport. A lot of the used lighter units I looked at had bent quills so I figured that A) somebody else had been trying to drill big holes in thick metal and B) the units hadn't been up to the task. Or else people had been using them for an arbor press. /forums/images/graemlins/confused.gif An industrial drill press this size is probably $1000 up new so that was out of the question. This is basically a toy, I doubt I'll do anything on it to justify paying that much for a new one. It will, however, save me from loading stuff up and hauling it to my buddy that has a machine shop.
/ Drill Press
I think it's well worth the $275, I was just disappointed that I couldn't talk him down to $150. /forums/images/graemlins/smirk.gif My machinist buddy had told me that .005 was acceptable runout on a used drill, I ran it out with a partially frozen dial indicator under adverse conditions where the unit was located. I didn't realize how tight this thing actually was until I got it home and cleaned up and checked it with a good indicator. This thing has no visible wear on anything like the rack on the quill or the pinion gear that moves it up and down. Someone will probably get a heck of a deal at my estate sale. /forums/images/graemlins/smile.gif
/ Drill Press
I forgot to put in the tractor content. This drill was located probably two miles from my house across the freeway. There was no way that me and the guy I bought it off of could load it into my truck without busting something ( us or the drill) so I went and got my TN 65. I chained it to the loader and raised it up and then chained it to the front bumper to keep it from swinging. It danced around a little when I hit potholes but other than that it rode fine. /forums/images/graemlins/grin.gif
/ Drill Press #19
Brad,
There is some good info about Buffalo Forge here . The old wood working machines site has a lively forum also.
Bart
/ Drill Press
I checked out Buffalo Forge's site, the current No. 18 sure doesn't look as heavy duty as the old ones, do they?
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63291)
KNOW BEFORE YOU...
2012 Ford E-450 Sewer Viewer Van (A61573)
2012 Ford E-450...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
2023 Deere 317G (A64119)
2023 Deere 317G...
2006 Ford F53 Landau 3645DS 36ft. Class A Motorhome (A61574)
2006 Ford F53...
Craftsman 33 Gal Air Compressor (A64119)
Craftsman 33 Gal...
