Drilling Holes in Roll Over Bar for Lights
   / Drilling Holes in Roll Over Bar for Lights #61
not for me, did you not see the wink?
I bought 2 things from there and wont go back
   / Drilling Holes in Roll Over Bar for Lights #62
Back to the original subject of this thread -
The following link takes you to my solution to the problem - using only the original factory holes:
http://www.tractorbynet.com/forums/customization/230506-my-work-light-installation.html
I tend to agree that some small holes should not really damage the ROPS. However, I did not want to do that on MY tractor!
I have since plowed the driveway in the dark many times, and they work great.
Hi Dennis, yes I saw that earlier, the only worry I have with it is that its a bit unprotected for the bush work I do (ie I've already replaced an indicator light), thats why I went for under ROP. Had my new lights working for 2 weeks now and am very, very happy - just by using 2 simple clamps and the existing holes in ROP to run the wire.
I never intended to create such a fuss when I started this thread....... but all the different ideas were helpful and the result is excellent. Cheers OzG
   / Drilling Holes in Roll Over Bar for Lights #64
OzG -
Never worry about making a fuss when you start a thread to ask a question in this forum. There are several around who like to argue (and re-argue) the same old questions. I've seen a lot of threads that got way more ridiculous than this one.
Glad you came up with a solution that worked out for you, and that you got some helpful advice. That's what it's all about!:thumbsup:
Remember, free advice (whether from me, or anyone else on here) is always guaranteed to be worth at least as much as it costs.:)
   / Drilling Holes in Roll Over Bar for Lights #65
The reason I went against it, is because I want to mount my gopro camera on my ROPS sometime to video backing through large saplings with my rotary cutter, and the strong magnet will interfere/wipe out the camera.
A magnet, even a large neodymium, should have no effect on a GoPro camera. For example, I have placed a 1/2" x 1/2" by 2" neodymium magnet on my iPhone to prove the point. It had no effect at all.
A tape based video camera could have a problem since the data is stored on magnetic media...
   / Drilling Holes in Roll Over Bar for Lights #66
Just purchased a new Kioti CK35H, but its not currently at my location. I am in the planning stage of adding work lights on the rop unit and trying to determine the measurements for the mounting brackets that I plan to make myself. By question is this, does anyone know the size of the channel stock that the rop is made of? Width and depth?
   / Drilling Holes in Roll Over Bar for Lights #67
I drilled and tapped mine, never looked back.
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56436)
LMC 2-Row Planter...
2002 Kenworth T300 TMA Attenuator Truck (A55973)
2002 Kenworth T300...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A56858)
2013 Ford F-550...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
