Egon
Epic Contributor
The rear blade and add gauge wheels. It will make life much easier. The Father in Law will be impressed. He'll figure he sure raised a clever girl to find such a competent man!
The object is to pull the gravel on the shoulders up to the roadway and also mix the fines with the coarser rocks to make a packable mixture and lay it all down smooth with a center crown to shed water.
Pull all the gravel on the shoulders to the middle and then make some passes rolling a windrow from side to side. End up leaving the windrow in the center and then splitting it in half laying each half down on its side of the driveway.
Do it a few times and it all becomes self explanatory.
The size of your tractor will also dictate how much of a windrow you can pull.
