Driving on side slopes
   / Driving on side slopes #1
robertk
calif.
tym 450
My property is hilly with different degrees of slopes. the steepest is about 26 percent which is about 15 degrees. I drive up and down and across but very slowly with my loader kept low. As many times as I've done It I still don't feel comfortable in the seat.I was just wondering what type of slopes you guys drive on and what you consider just to steep to drive on? also what type of tractor are you driving?
Bob
   / Driving on side slopes #2
When I start to slide down the hill on dirt it is too steep.
I ride it out on 2 to 1 slopes & even some 1 to 1 stuff.
I do erosion control in Iowa so I see some pretty nasty stuff.
People think I am nuts to go on some of them.
Tires I buy always have to have the 2 piece rims and they are dished out as wide a they will go.
You may want to see if that is possible on your tractor.
You are right to carry your loader low. But it does not always work.
Weight on the rear will also keep your rear down better too..
see my profile to see what I use.
I just ordered a 6500 mahindra july 26 & should be getting a new 4530 jd in the next week & trading in the 4500.
also I have never had a tractor on its side or go over nor any employee thankfully.
I have had to hook up another tractor & or skid loader to stop me though or get me out of a predicament after I have started to go.
did have a rear tire off the ground about 2' one time.
Another when I was spraying for the railroad I went to turn around on the hill and felt it start to go so I hit the left brake as the right tire was coming off the ground, and swung the tractor around so it was headed downhill.
Yes I have had my breath taken away & had major adreniline rushes or whatever you want to call it.
Biggest thing is do not do what I do.
Be Careful.
Stay off those types of hills. Especially sideways.
   / Driving on side slopes #3
I have quite a bit of slope on my field. It doesn't bother me much until I have something in the loader or I hit a bump. When I hit a bump one of the rear wheels can come off the ground pretty easily. Just a little while ago I had to move about 21 truckloads of dirt from one place to another. Unfortunately, the trucker dumped the dirt in a location where I could only get at it from the side of a slope. I looked into widening my back wheels, but found no good way to do it. I ended up attaching my bush hog to the back and keeping it on the ground. That seemed to help quite a bit. I always kept the FEL as low to the ground as possible. Bottom line....drive up or down if you can, lower your CG and widen your wheels if you can't. Filling the rears can help but since I mow around my house I didn't want to do that.
   / Driving on side slopes #4
Zipp, I was wondering what is the steepest slope you feel comfortable travelling up and down? The 15 degree side slope is about the max for me while mowing as the rear end tends to slip down the hill from the weight of the mower. I have no loader and my rears aren't loaded. Would spreading the rears out and or loading help keep it planted? I've been somewhat hesitant to load tires as I primarily mow with the tractor and wanted to keep the weight down.
Thanks,
John
   / Driving on side slopes #5
IMHO excessive weight on a tractor for traction/stability can be worse on hills than less weight. Gravity sort of wins if you put too much weight on your tractor to the point where you can lock your brakes up and still slide down the hill.
   / Driving on side slopes #6
I have a lot of slopes on my property greater than 15 degrees and I've resolved that any that I would have to go sideways on greater than 15 degrees to leave alone. I will go up and down on greater than 15 degrees but very slowly. Traveling sideways on a slope at 15 degrees, twice I've had a wheel to drop in a hole I didn't see on the low side and pegged the tiltmeter (25 degrees). Fortunately I was going slow and the tractor seemed pretty stable. I very s-l-o-w-l-y turned up slope and decided to do something else for a while. Going sideways at greater than 15 degrees for me is in the margins of safety, by that I mean I could do it, but I no longer have a buffer for the unexpected -like a hole. I know others do these kinds of slopes, but not me. Dying in a tractor roll over does not appeal to me.
   / Driving on side slopes #7
After a discussion on another site I checked the slope on the hill I bush hog and found it to be about 20 deg. I have not had any trouble but it is as steep as I want to be on sideways. If you feel like it is tipping over always try to turn downhill. Turning uphill will add to the momentum of the roll. You should turn into the roll to counter the tipping motion. A high spot uphill or hole downhill can tip the tractor before you can react so be carefull. I have slipped into a ditch that was maybe 30 or 40 deg but steered out as quick as I could and it didn't roll over. If you steer into the ditch it may tip over when it hits the bottom of the ditch. It did tip and bounce a little. There are a few places I won't go on my 7 acres.
   / Driving on side slopes #8
Well a couple weeks ago I almost rolled on my 15 degree slope. Had a front tire come up off the ground and I was about halfway there. I think my mistake was not coming down the hill straight. I was at an angle. So I am not going to comfortable with slopes, especially until a ROPS is available for my tractor. One is supposed to be soon and I will buy it.
Slowrev, I understand what you are saying about more weight = less traction when in the braking mode in some side slope conditions, but do you think more weight, such as filled tires, would be an advantage when only using the tractors low gears for acceleration and braking on slopes?
Bob
   / Driving on side slopes #10
Tractor sitting on about a 17 degree slope. It does see more extreme slopes.
   / Driving on side slopes #11
Anyone have any more pics of tractors on slopes?I have no idea of the angle of the slopes in my back lot and still haven't tried em.Still chicken.
   / Driving on side slopes #12
i am trying to attatch a pic but not sure if it will work so please bear with me.
I could not get the one I wanted but here is a place you dont want to go.
We got it out with our 4500 john deere.
   / Driving on side slopes #13
zipp,
It's a "little" small...
   / Driving on side slopes #14
the only camera we had was our cell phones.
That is all the bigger I can resize it and not lose the picture as it just makes it blurry when I enlarge it.
   / Driving on side slopes #15
here is one slope on the Des Moines river bank where we were pulling silt fence this past spring.
   / Driving on side slopes #16
The guys I tip my hat to are the ones who run the mowers along the highways for the State. I have seen them on slopes that I would not touch for any amount of money.
   / Driving on side slopes #17
Bob
I'm a huge fan of filled tires for stability on slopes. My property is quite hilly and there are several places that I do *not* even dream of going along the side of the slope. Up and down, in many places I only back it up (less likely that the tractor will flip forward), others I dare not go.
I don't have trouble with slippage unless I'm only running 2WD, but this is an area (braking) that my HST helps a lot. I rarely use my brakes - the transmission will stop me, even on the steep slopes.
   / Driving on side slopes #18
I mow a ton of 15* side slopes as well as quite a bit of 20*. The 15s aren't to bad, but I don't like the 20s at all. Either degree can get you in trouble if you hit a rock, stump or hole. Anything above 20*, I mow up and down.
   / Driving on side slopes #19
Zip I wonder what angle that is on. Looks like it would flip to me.I have nothing that steep on my land so maybe I'm fine with my slopes.
We'll see.
   / Driving on side slopes #20
We'll see.
I would never consider a slope just because someone else did it. My tractor might not be set up like theirs. Look how far out he has his wheels set. My Bota won't go that wide.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
NEW Woods 6ft Finish Mower (A56438)
NEW Woods 6ft...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
Hydraulic Liftgate (A59230)
Hydraulic Liftgate...
2004 Mack CV713 Granite Fuel and Lube Truck (A59230)
2004 Mack CV713...
