Drying up the front yard
/ Drying up the front yard #11
That just might do the trick for you. Looks like a reasonable solution. Is that 4" perforated pipe around the tree?
Yes, that's four inch perforated pipe around the tree.
Even though its base is going to be covered with gravel and topsoil, with grass planted on top, the willow tree should be fine because the water will still be filtering down to its roots.
/ Drying up the front yard #13
Please check with an arborist. I always understood that generally you could not add more 2-3 inches of fill over the root zone of a tree per season without risking killing the tree.
Vernon
/ Drying up the front yard #14
Willows are a little different, but most trees do not live long if you pile up dirt on their trunk & burry their root system - I would plan on losing the tree.
Sounds like you have things worked out pretty good, but why bother? /forums/images/graemlins/smile.gif Water runs to the lowest point, so might as well leave it there.
Where I live, there are _real_ issues with drain fields. You don't want to tamper with one whatsoever or draw any attention to one. The officials get real inspection minded. I would not wish to mess with a working curtain drain, or put more water into it. You might well be reverse-flooding the curtain drain until the pump can catch up with all the water you are feeding it - which appears to be a lot. You could saturate all the ground by the red line....
It's funny, on here I see people wanting to dig a pond in a sand front yard, and then you see others with a natural pond & go through all sorts of work to pump the water uphill & around & over.....
Guess we humans are just never happy with what we have. /forums/images/graemlins/smile.gif
(I have 200 acres of farmland & we had 4" of rain in under 3 days. The county ditch is running full because they had 5" of rain uphill from me. So my several miles of underground tile is mostly running backwards, adding more water to my fields. Probably lose 10% of my harvest this fall from the water ponds. I know a lot about drainage. Water always goes downhill. We think we can change that, & can sometimes influence it a bit. But can't make major changes.)
--->Paul
/ Drying up the front yard #15
</font><font color="blue" class="small">( The ditch that runs along the other side of the road is 2 1/2 to 3 feet deep. Several people here have tried to get me to run a pipe under the road to the deeper ditch, but I haven't been able to bring myself to bore under a county road! )</font>
You may be able to get an auger from Rent-All, and auger the road yourself. I've not used one, so don't know how difficult it would be to maintain grade. The advantage of augering under the road and tying into the lower ditch, is that you might be able to drain at least some of the water by gravity.
Gravity always works.
If the ditch on the far side isn't low enough, then you'll not gain much by augering under the road.
Even though the gravel is being piled around the base of the tree, I figure it shouldn't be a problem, since all of the water is still flowing under the gravel. We've only kept it there to help soak up the water that had gathered in the front yard. I'd like to keep it, but if I made a mistake and buried the roots too deep, it's no big deal to me or my wife if I have to cut down a dead willow tree. /forums/images/graemlins/crazy.gif /forums/images/graemlins/blush.gif
Because of the rain, I didn't get much seat time in the past two days, but I've managed to spread a little bit of gravel over the drain lines in between rain showers.
It takes a bit longer to spread when you don't have a front end loader, but the job's getting done none the less.
Spreading gravel with a tractor or two sure beats raking it out by hand, which I've done a few times in the past and I don't want to do again unless I have to! /forums/images/graemlins/smirk.gif
A view from the other direction...
Still a little bit more gravel to spread tomorrow... /forums/images/graemlins/wink.gif
/ Drying up the front yard #18
Looks good so far........ sure you don't want me to take that old relic red tractor off your hands? I'll come out and pick it up and give you a hand loading it on my trailer. Even let you buy me a cold one at that..... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif That is the least that I can do for a friend...... /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
<font color="blue"> Looks good so far........ sure you don't want me to take that old relic red tractor off your hands? I'll come out and pick it up and give you a hand loading it on my trailer. Even let you buy me a cold one at that..... That is the least that I can do for a friend...... </font>
Uh, NO! /forums/images/graemlins/mad.gif
I tell you what-- If you come down to PA next Saturday for our TBN meeting, I will buy you lunch and you can see my projects in person, but you can't have any tractors! /forums/images/graemlins/crazy.gif
Even though we've received all this rain the past two days, it sure is nice to be able to go out to work in between the showers and not have to wait for the water to drain. Do you think I would have been able to drive a tractor under the tree after six straight hours of rains last week? /forums/images/graemlins/grin.gif /forums/images/graemlins/smirk.gif
I love it when a plan comes together! /forums/images/graemlins/cool.gif
/ Drying up the front yard #20
</font><font color="blue" class="small">( ...................... Do you think I would have been able to drive a tractor under the tree after six straight hours of rains last week? /forums/images/graemlins/grin.gif /forums/images/graemlins/smirk.gif )</font>
We all live in a Yellow Submarine..... Yellow Submarine... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A60736)
2012 BRUMLEY...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
MGY Shop Heater (A60463)
MGY Shop Heater...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
