Dt466 not firing on front cylinder.
   / Dt466 not firing on front cylinder. #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
I plan on buying a truck with a international dt466. It smokes like a tar hill and I pretty quickly figured out the front cylinder isn’t firing. I’m thinking either the injector is stuck open or that cylinder has no compression. I’ll probably put another injector in that cylinder and see if that fixes it. Any other ideas? And I’ll probably drive it 10 miles home with 5 cylinders. Is there any problem there?
   / Dt466 not firing on front cylinder. #2
swap the dead cylinder's injector with another cylinder injector and see if it fires and the other cylinder goes dead.
I’d planned on pulling a injector from another dt466 that I have.
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
Tube Broom 8, 5/8 x 58 Poly 26" (A59076)
Tube Broom 8, 5/8...
LOT OF 1" THICK X 4" FLAT IRON (A58374)
LOT OF 1" THICK X...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
Terms & Conditions of Auction (CHECKOUT DATES) (A59213)
Terms & Conditions...
2019 Freightliner M2 106 Water Truck (A56858)
2019 Freightliner...
