Dt466 not firing on front cylinder.
   / Dt466 not firing on front cylinder. #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
I plan on buying a truck with a international dt466. It smokes like a tar hill and I pretty quickly figured out the front cylinder isn’t firing. I’m thinking either the injector is stuck open or that cylinder has no compression. I’ll probably put another injector in that cylinder and see if that fixes it. Any other ideas? And I’ll probably drive it 10 miles home with 5 cylinders. Is there any problem there?
   / Dt466 not firing on front cylinder. #2
swap the dead cylinder's injector with another cylinder injector and see if it fires and the other cylinder goes dead.
I’d planned on pulling a injector from another dt466 that I have.
2012 CAT 316EL (A55272)
2012 CAT 316EL...
DOOSAN  G25 GENERATOR (A58216)
DOOSAN G25...
2010 KENWORTH T800 (A58214)
2010 KENWORTH T800...
2015 Peterbilt 365 Quad Axle Altec AC45-127S 5 Section 45 Ton Crane Truck (A55973)
2015 Peterbilt 365...
2015 CASE 621F WHEEL LOADER (A58216)
2015 CASE 621F...
2018 Bandit 15XP Wood Chipper (A57453)
2018 Bandit 15XP...
