Dual Clutch Not working.
   / Dual Clutch Not working. #11
I've never given the underside of a Futian/Foton a close inspection. But I'd expect to find a weephole under the clutch housing. The three Chinese tractors I've had so far (2 Jinmas and a KAMA) all have one, to permit moisture/condensation to drip out rather than accumulate. Part of your remedial maintenance should include finding that weephole. Assuming it exists, it should be cleared of rust and debris as well.
//greg//
thanks all for your comments, The only implement I have yet is a 4.6ft slasher so it was not a great deal of load (just heavy grass) I am not sure how much load to try without breaking something internal. I did find a weep hole with a split pin in it so i have cleared it, thanks for the tip. The manual I have is VERY basic and does not say much about anything.
I did internally adjust the secondary clutch and it felt a lot better, but it still wont stop the pto turning, I can see through the inspection hole that the pto clutch plate is seperating from the pressure plate, so is it possible for it still to be stuck somehow. I pray to god that I can find an awnser because breaking the tractor sounds very expensive.
Cheers Everyone.
Jabiru.
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2022 Wacker Neuson SM100 Mini Skid Steer (A52128)
2022 Wacker Neuson...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
Kubota SVL95-2 High Flow Cab Skid Steer (A52128)
Kubota SVL95-2...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
