Dug well Caisson
   / Dug well Caisson #21
Eldorado .... I too have thought about using black plastic culvert pipe. I thought that I would drill holes in the bottom part of the culvert pipe to let water seep in and filling up the outside of the pipe with gravel partway up. I am glad to hear someone did it now I know that my idea wasn't nutty after all and that it would work. I wonder about the galvanized culvert over the black plastic though. When we were kids we all drank out of a zinc water bucket and a dipper, I wonder if that zinc water bucket was actually a galvanized bucket, might have been.
<snip>
PS why did this quote not come through as a highlighted quote?
You didnt end with a [/QUOTE] (as I did above), thus it didnt see it as a complete quote.
Aaron Z
   / Dug well Caisson #22
handirifle ,, Your right about the type of plastic.. Drinking water bottles are a much finer plastic than a plastic oil can...I'm sure that well casing plastic and culvert plastic are very different..
Tfhe other option would be to use the white PVC? pipe used for water mains. 13 foot sticks. Limited to about 24" diameter though.
   / Dug well Caisson
toy.. I am going to put sand and fabric around the sides,, Not sure what kind yet.. some sands pack too tight but others will lock together and allow more water through.. I think???
   / Dug well Caisson #24
Around my well I used, what they call up here, wash rock about 4-8 inches in diameter. Then I also added a #2 round rock to that. My well is 10-+' deep it is used for our 3 bathroom house.
   / Dug well Caisson #25
I heard them say on the news that plastic water bottles had something in them that wasn't safe, I don't know but I never did like drinking out of plastic I want my water in a glass and my soda in a can but this new warning scare that they have come out with didn't have anything to do with it.
   / Dug well Caisson #26
Aczlan in your post 21 I never hit the quote, I used the reply and just typed in Eldorados name, I never intended to have a quote. Is that not an acceptable way to do it? I am not very proficient in computers.
   / Dug well Caisson #27
It's acceptable, but once several begin responding, it becomes easier to follow the conversations/responses when the quote or multi-quote are used to reference what you are responding to.:thumbsup:
Sometimes people will then edit the quote so only a portion will be quoted to make things even clearer.
IE:
   / Dug well Caisson #28
It is preferable to quote the person you are responding to so that others can follow the thread of teh conversation better.
If you want to quote someone's message, you can click on the "Quote" button in the lower RH corner of a message, then it will come up with a reply box that has the quoted text pre-entered and ready to go.
Aaron Z
   / Dug well Caisson #29
What about a culvert on end? I did that for a well at our camp and it works fine. The retailer would not sell me a plastic one once he found out that we were going to be consuming the water, I had to buy a galvanized metal one (go figure- galvanized safer than plastic???).
I placed about 15 inches of crushed stone on the bottom, installed the culvert, and place around 1 foot of stone around the culvert (4 foot). I then attached a pitless adapter to the culvert and around 6 feet of copper going down into the well. The pump and pressure tank are in a small pumphouse and I have a wooden cover on top of the culvert and keep the pumphouse locked to keep out the kids.
This works fine. There is usually around 5-6 feet of water in the culvert x 4 feet in diameter is a lot of water. Oh yeh, I dug down until I hit ledge which was around 9 feet. The culvert was 10 feet long - the pregnant wife and I muscled it from the horizontal plane to the vertical plane.
Good Luck!
Lead is used to stabilize PVC pipes used outdoors, that includes your water hoses!!!! Lead leaches out of the plastic into standing water, worse in the heat of the sun, so plastic used for drinking water does not contain lead stabilizer..
I know this first hand, we lived in a travel trailer for a few years, and I hooked up the trailer to the well pressure tank using garden hoses. Yep, went down with lead poisoning!!!
   / Dug well Caisson
Not sure it inserted the quote right toy,, :confused: But John,, Wow,, never heard of that,,glad your ok..?? I'm still looking at the pressure treated method,, but i'm not going to use it for drinking,, just for keeping the pond full.. Hope the ducks don't mind,,
22ft Rollback Flatbed Body with Winch (A51692)
22ft Rollback...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2022 Big Tex...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2015 Toro Workman MD Utility Cart (A53421)
2015 Toro Workman...
