Dump trailer
/ Dump trailer
Thanks cylinder calculator shows 0.7343 gal = 2.9 quarts should work dont want to burn out pump
/ Dump trailer #12
I lost 4-5 gallons with a blown cooler line (hst) and was able to drive back to the house to make repairs. You should be fine with a few quarts missing.
/ Dump trailer #13
I have this issue with a sizeable single acting hoist. It is so close that whether the pump goes into cavitation or not, depends on the position of the loader and 3PH. Not a good arrangement.
/ Dump trailer #14
I'm running a 4" x 24" on our 4' x 8' Country Mfg. dump cart powered off the rear remotes on our B2910.
No problems here, so I'm guessing you'd be ok.
/ Dump trailer #15
I'm running a double acting 4x48 off the remotes of mine without problem. I wouldn't be the least bit worried about 3 quarts. If you are concerned, do the math on how much fluid the loader uses to be at max height with the bucket dumped compared to on the ground with the bucket curled all the way back. I'm sure that would be a similar number.
/ Dump trailer #16
With a double acting cylinder you only have to make up the volume occupied by the rod. With a single acting cylinder, you also need to make up the volume of the whole cylinder.
Our B7500 has issues running the cylinder on the dump wagon (single acting 5 or 6x30ish?) but the L3830 has no problems with it.
Aaron Z
/ Dump trailer #17
Aaron Z
Yes, that's why I made the loader reference. With the loader compared to his dump wagon there are 4 cylinders vs the one. Accounting for a 1.5" rod, 4 DA cylinders would have the same fluid displacement of one 3" SA cyl on the base end for a given stroke length.
/ Dump trailer
I will make it a double acting piston then it will use about 1 qt of oil to be on the safe side a hose is cheaper than a new pump
/ Dump trailer #19
Peter 315 I believe you are doing the right thing. And I am sure your math is correct given the price of a pump.
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
Dual Rear Wheel Axle (A59230)
Dual Rear Wheel...
2012 International (A59230)
2012 International...
2014 Ford Escape SUV (A59231)
2014 Ford Escape...
2017 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2017 DRAGON 150...
Sakai SW354 (A60462)
