Durable Tractor Paint
   / Durable Tractor Paint #1
ADin
Indiana
JD2305, 1948 B.F. Avery Model V
For repainting after welding or re-painting attachments to match tractor color, etc.. is there a type of paint, painting process/technique, or additional guidance on how to achieve the most durable finish?
Anybody like to share what they have found to work the best or point me toward old archives I can't seem to find with the search?
   / Durable Tractor Paint #3
I've had excellent results with the brush-on oil based Rust Oleum primer. That, combined with the Rust Oleum black gloss oil-based top coat holds up incredibly well. I painted this combo on a toothbar that I fabricated a few months back and have been pleased with the results.
   / Durable Tractor Paint #4
   / Durable Tractor Paint #5
I've been using BPS paints from tsc, as you can match many manufacturers paints. I use hardner which modifies cure time, increases gloss/finish, and makes the paint more durable to chipping, and sun fading.
BPS paint falls into the economy line of paints.. like 26$ per gallon. Some guys use stuff int he 300$ a gallon.
I can see that for a parade tractor.. but for something digging in the dirt.. no matter what you7 put on it.. the paints gonna wear fast..so i liek the cheaper stuff.
I've painted up a couple parade tractors that look great using that paint too..
Soundguy
   / Durable Tractor Paint #6
Soundguy
   / Durable Tractor Paint #7
</font><font color="blue" class="small">( I've had excellent results with the brush-on oil based Rust Oleum primer. That, combined with the Rust Oleum black gloss oil-based top coat holds up incredibly well. I painted this combo on a toothbar that I fabricated a few months back and have been pleased with the results. )</font>
Same here. In fact I recommend this same procedure with Rust-Oleum in all the plans I distribute. One coat of primer then 2 coats of brushed on protective enamel will give a strong durable finish even for 3pt implements.
   / Durable Tractor Paint #8
   / Durable Tractor Paint #9
Hi ADin,
Good surface preparation and priming are the 2 biggest things to keep new paint on a surface...
I'm in Soundguy's camp on this one though--work eventually removes all of it! /forums/images/graemlins/grin.gif
   / Durable Tractor Paint #10
Hi ADin,
   / Durable Tractor Paint #11
I'm another thats had pretty good luck with the TSC paint, sprayed or brushed.
   / Durable Tractor Paint #12
   / Durable Tractor Paint #13
You can't beat the TSC paint for bang for the buck.
Eugene
   / Durable Tractor Paint #14
Eugene
   / Durable Tractor Paint #15
ADin,
The most durable paints are urethane enamels that have catalyst added to them. IMRON is Duponts's brand, but there are others. The down side is that the stuff is poison. It is NOT caught with a charcoal mask. You have to use a supplied air respirator that pumps air into a helmet that you wear. The catalyst action in paint is to cross link and harden it providing excellent wear resistance, high gloss, UV protection and color retention. The biologic action is to make a PERMANENT coating on the inside of your lungs. Eventually, you will have the lung capacity of a 90 year old 3 pack a day smoker.
If you go to ytmag.com and read the discussions in the painting forum, you will learn a lot. (I did) Basic technique is to clean the parts of all old paint, oil, rust down to bare metal. Use a phosphoric acid based rust preventer like "Must for Rust" to treat bare ferrous metal. Use a good quality primer and good quality paint. Follow directions exactly on time to recoat and sanding. A good quality HVLP spray gun or even a cheapie will give better results than brushing in most cases.
jb
   / Durable Tractor Paint #16
ADin,
jb
   / Durable Tractor Paint #17
BPS or Van Sickle are the usuals around here. Between TSC and all the rest of the Ag supply business's here carry one of the 2. Either will work satisfactory, and at a relatively low buck.
IF...you have all the right equipment to do your painting, and you're painting an entire tractor or implement, there are much better paints, with a MUCH bigger price tag. Once again, IF...you clean, sand, prime, sand, prime some more, sand some more, and so on, these expensive paints will last longer in most cases, keep their shine longer, and protect longer. It's a big jump from $25 enamel to $200 base coat/clear coat in terms of what you need to know and have to spray it.
For "the average guy", the stuff from TSC does the trick.
(After painting a few things, I'm learning the uses of different types of reducer. Mostly to match with climate conditions. It helps if you can find a good automotive paint dealer with a helpful counter man. Bottom line is, you can't go too far wrong with the thinners recommended by paint manufacturers)
BE CAREFULL IF YOU USE HARDENERS IN YOUR PAINT! (read directions CAREFULLY)
   / Durable Tractor Paint #18
   / Durable Tractor Paint #19
I used TSC paints with a hardener and sprayed on with a touch-up sprayer that I bought at TSC using my Clack Champ oil type compressor, all bought at TSC. So far, the paint on my soil ripper with 2 disc hillers added has stayed through one use.
If you have ANY rust at all, I recommend coating it with one of the rust converters like RustOleum Rust Reformer or other products from NAPA and others. They turn the iron oxide, even some of it you won't see in crevices, into iron sulfide, a very hard, black surface that is paintable with primer. I've NEVER had ANY paint stay on over rust unless it is inerted first with one of these rust converters.
Ralph
   / Durable Tractor Paint #20
Ralph
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
2016 KOMATSU D65EX-18 CRAWLER DOZER (A60429)
2016 KOMATSU...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
