Easily Removeable Toothbar?
/ Easily Removeable Toothbar? #1
RichZ
White Creek, New York, Washington County, on the V
Kubota 4630 with cab and loader
Are there any toothbars that are easily removeable? A toothbar would be handy on one of my loader tractors for moving manure, but I might want to take it off for other uses, like moving snow. I know that most bolt on, and I figure that the bolts would soon become very difficult to get off with the amount of manure I move. Are there any toothbars that clip on instead of bolt on?
Thanks for any info!!
/ Easily Removeable Toothbar? #2
You could probably work with a company like Markham Welding to modify the standard bar to do just that. A loop thru the side of the bucket with a pin on the outside. You would probably want to weld on some bar to protect the pin, but that's easy enough.
jb
/ Easily Removeable Toothbar? #3
Instead of the bolts on a bolt on toothbar, use pins. It may rattle a bit though. My bolt on takes about 2 minutes to remove.
/ Easily Removeable Toothbar? #4
Here is my set-up and it works great and fully removable.
/ Easily Removeable Toothbar? #5
I switched the stainless bolts to avoid the rust problem.
/ Easily Removeable Toothbar? #6
skippy: did you make that or buy it set up like that?
/ Easily Removeable Toothbar? #9
Out of curiosity, why do you want a toothbar for moving manure?
I just took my toothbar off for the winter and I generally find moving material, including manure a bit easier without it.
I find that being able to get slightly lower right to ground level with the bucket is nicer and I also find that I am less likely to dig into the ground when I didn't mean to without the toothbar on. That said, bear in mind that I am no pro at loader work so it is not atypical for me to dig in a bit when all I meant to do was scoop up that last load of manure.
I think that in general I will be keeping my toothbar off until I actually need it for a project.
/ Easily Removeable Toothbar? #10
Generally mine stays on throughout the spring/summer/fall digging season and comes off for winter digging. Like I said generally, but it really comes on/off so easily I can change the setup in five minutes(including time to find the wrenches).
I wouldn't personally worry about using bolts just so long as the bolts aren't too long and you have excess threads sticking out beyond the nut on the outside of the bucket. If they get boogered up it could be make dismounting the bar tough. I would worry about losing pins.
The manure that I'm referring to is more like dirty hay, which I use for bedding for my goats and sheep. I have a kid working for me whose main job is mucking the barns, and he has to use a wheelbarrow, because I can't get a tractor in my barns. So he dumps the wheelbarrows of manure in an area, and I pick it up with my loader several times/week. I have over 100 goats and about 30 sheep, so we're talking a lot of maure. It isn't always easy to pick it up with the loader, depending on how wet and packed down it is. A toothbar would make it much easier to pick up.
/ Easily Removeable Toothbar? #12
Rich
What about when you drill bucket for tooth bar drill it in the front of the slot and loosen bolt slide it forward and flip it in to bucket would that work?
Tom
/ Easily Removeable Toothbar? #13
Rich, The Toothbars come off very easily with the Nut & Bolt arrangement.
I can't imagine what manure would do to the nut & bolt in the near term.
If it's corrosion you are thinking would be a problem, you could use a Nylock bolt and some lithium grease or teflon tape on the threads, the nylon insert tends to seal the threads.
If you are removing it several times a year, It will only get easier each time.
I can understand how the toothbar helps picking up piles of manure. I would go ahead and bolt it up, use it, and unbolt it as needed to remove. With a pneumatic impact gun we are talking 60 seconds to remove. With socket wrench a couple minutes, tops.
Stainless could get pricey for 3/4" hardware, you could probably replace the Nut Bolt combo every year or two, push come to shove.
What is your concern? corrosion of the bolts? or just basic mechanical removal?
Yes, my concern is corrosion. I figure I'd have it on most of the time, and only occasionally need to take it off, and when I did take it off, I thought that it might be corroded on. But your ideas sound like they'd prevent that.
/ Easily Removeable Toothbar? #15
My 1/2 hardware cost me $8. It was worth it.
/ Easily Removeable Toothbar? #16
My Markham just slides over the edge of the FEL and bolts via 2 big bolts at the side. It's easy to put on and off. I leave the bolts in the holes now, as I occasionally will use the bolts for attaching something else. They haven't rusted. The toothbar stays off except for the rare dirt digging need.
Ralph
/ Easily Removeable Toothbar? #17
2014 KUBOTA R520ST WHEEL LOADER (A65053)
2014 KUBOTA R520ST...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
213101 (A64276)
213101 (A64276)
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
2018 MULTIQUIP TOWABLE GENERATOR (A63276)
2018 MULTIQUIP...
3145 (A63117)
3145 (A63117)
