Eatin' belts
   / Eatin' belts #11
Well, it's your machine, so I don't care how you do it, since I know that I'm not going to be buying one that you've owned before me.:laughing:
It almost sounds like you're saying he doesn't know what he's doing. Not very helpful. Here on TBN we like to be cordial and helpful. Now say you're sorry and shake his hand! Go on, say it!
   / Eatin' belts #12
Sorry for what. I told him I don't care what he does to, or how he uses, his equipment, and I don't. I did not say he doesn't know what he's doing because I don't know whether he does or not. So, burnieman, you assumed facts not in evidence.:laughing: But I, personally, would not want to buy a used one that he's owned. Simple statement of fact. Maybe he wouldn't want to buy one I've owned, and if so, that would sure be his privilege, and I would have no hard feelings, and I wouldn't think he owed me any apology for his opinion.:laughing:
   / Eatin' belts #13
Since you are in Texas & I am in Indiana, you would never have the opportunity to buy any of my used machines anyway because dealers always have a waiting list for my used John Deere tractors & equipment.
   / Eatin' belts #14
Ditto on pulley alignment and checking pulley wear.
Also, what brand belt are you using?? Some cheap china belt?? Or a good kevlar USA belt??
Might have to (watch out for the safety police) run it with the covers off to see what is going on.
   / Eatin' belts
Thanks for helpful tips. This weekend I will pull the deck and check level on the pulleys. Low rpm not the problem I keep her wound up most of the time
   / Eatin' belts #16
And you may know more about the machines than I do, which wouldn't be any big surprise.:laughing:
You might even know more than the manufacturer, but that would be a bit of a surprise, although certainly a possibility.:laughing:
I cut and baled hay with a bigger tractor, but used 2 different small Kubotas with a tiller and rotary cutters; one with a finish mower, and for all those jobs, I used the manufacturer's "PTO speed". I now have a little Toro ZTR and the manual in more than one place says to engage the blades and mow with the throttle in the "Fast" position. So, yep, it might use a bit more gas, but I'll take that chance.
I even service and operate my car and pickup as the manufacturer says to do it.:laughing:
One of the things I was taught in an unrelated occupation, but I think applies to all, was to go by the book until you know more than the book. So maybe you know more than the book, but I don't.:laughing:
   / Eatin' belts #17
My dim witted kid smoked the belts of the mower twice and burned some extra fuel while taking a long time to mow the lawns. Turns out the dumb azz kept turning right and kept re-mowing/re-mulching the clippings from the previous passes. Caught him doing the 3rd time and he went wailing to his mother about the boot print on the seat of his pants.
   / Eatin' belts #18
kept re-mowing/re-mulching the clippings from the precious passes
So what's wrong with that? I sometimes do it myself to mulch and scatter the clippings instead of leaving a thick windrow.
   / Eatin' belts #20
To address the original issue, I wonder how the blade spindles turn with belt tension on them, rather than when they are free to turn with no side tension.....
I think there is a back bevel on the top edges of the belt. Could the belt be inside out ? KnowwhatImean.......
I also have an 855 with a 60" deck. The only issue I have had is with the bearing going out of the tension pulley and needing replaced....
Good luck
Dewalt D28499 7/9" Angle Grinder/Sander (A59076)
Dewalt D28499 7/9"...
Cushman Electric Cart (A55851)
Cushman Electric...
Poulan 25cc Leaf Blower (A57454)
Poulan 25cc Leaf...
2009 CHEVROLET SILVERADO 1500 (A58214)
2009 CHEVROLET...
2021 Ford F-150XL (A57148)
2021 Ford F-150XL...
2012 John Deere TX Gator Utility Cart (A56857)
2012 John Deere TX...
