BufordBoone
Platinum Member
The M7060 we just got has Economy PTO. To engage, you move a lever at the rear of the tractor. Doing so gives 540 rpm on the PTO at approx 1800 engine rpm (vs. the normal ~2200 engine rpm).
I understand that this setting is designed for situations whereby the PTO is way over powered for the task at hand. For example, were I to hook a 4' cutter to this tractor, EPTO would be more than sufficient.
I have read another poster that uses his (same tractor) EPTO for wood chipping and stump grinding.
How should an operator determine when to use EPTO and when not to?
We cut the grass around the cabin every week or two weeks. Therefore it is never very long or heavy. I'm assuming this would be a good EPTO task. On the other hand, we cut the fields twice/year. I'd think normal PTO would be most appropriate for thick, tall grass.
I'm interested in what others think and how they use EPTO with their tractors.
Thanks.
Thanks.
