Educate me on electric fencing
   / Educate me on electric fencing #31
This is kind of what I'm thinking of doing. They have the clips in white that will match my fence and I'm planning on screwing them right into the posts. I'm planning on putting the ones that are right up next to the posts at the bottom and then the ones that stick out five inches into the pasture at the top. My thinking is the extra distance at the top will keep the horses that much farther away from the fence.
The long ones are more prone to breakage so I just used the flat ones. Once they touch it the will stay well away from the fence. Also, the pvc fence is an insulator in its self.
Do the springs in the corners make a difference? I hadn't considered that. I was just going to pull it tight by hand and hope it stayed that way.
Eddie
It somewhat depends on the length of the run. I have a 300+ foot run that I have never had to adjust. Also you don't have to worry about pulling it too tight and breaking it.
   / Educate me on electric fencing #32
I share a 660 ft (1 furlong) fence line with my neighbor to the West. Her fence is 5-ft T-posts on 10 ft centers, insulators and two strands of steel wire. Don't know what charger she's using. This has to be the least expensive way to go. That fence was up when I moved to my place 10 years ago. I've never seen any of her horses within 3 feet of the wires.
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
2014 Bomag BW900-S50 (A47477)
2014 Bomag...
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
Galvanized steel fence (A53424)
Galvanized steel...
Pallet of Miscellaneous Mini Excavator Attachments (A52377)
Pallet of...
